'01-'03 GSXR forks - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Old 08-20-2019, 02:49 AM   #1
fastegg
'01-'03 GSXR forks
I couldn't afford a late model Gixxer front end and $250 to freight it to Australia... but i REALLY REALLY want a better front end.. The stock Goldvalved one just doesn't cut it... My fork tubes are very chipped and need replacing.. so.... looking... looking... looking... so... i bought a K3 GSXR600 upright front end.. the last fully adjustable upright Gixxer unit... $350USD with a guard inc freight from a local wrecker... Forks, clamps, axle & guard... I'm stocked... it'll be hear in a few days... A USD one would have been more than twice as much... it would have been over $1,000 plus fitting... Now I rode a 750F2 bike back in the day with these very front ends.. standard and they were amongst the best if not the best stock front end you could get... The 4 pot calipers i already have on my SV forks.. All the dimensions are almost identical... fitting 'should' be pretty straight forward... a 45mm fully adjustable front end.... Yes...Yes.. Yes... I'm happy.
Click image for larger version
ID:	43751   Click image for larger version
fastegg is offline   Reply With Quote
Old 08-20-2019, 03:05 AM   #2
darthnorton
darthnorton's Avatar
Bikes: 2002 Suzuki SV650
Miles Kms: 10k
Re: '01-'03 GSXR forks
Man those look beefy. Hope to see it on the bike soon
Sent from my LG-LS998 using Tapatalk
darthnorton is offline   Reply With Quote
Old 08-20-2019, 01:36 PM   #3
DemonRider
Bikes: '01 SV650S, '05 GSXR 750
Miles Kms: SVS 21,000, GSXR 5,500
Damn, those do look nice. Do the triples bolt up directly to the stock SV head or is there modification involved. Very interested in doing something like this if my revived SV needs fork work.
DemonRider is offline   Reply With Quote
Old 08-20-2019, 05:10 PM   #4
fastegg
Don't know yet... i'm expecting I'll have to press my stem out and have it fitted to the new headset... i'm hoping i'm not creating an expensive monster as I shouldn't be spending money I don't have on loopy projects...
Old 08-20-2019, 08:03 PM   #5
MotoTrackSide
MotoTrackSide's Avatar
Bikes: 2nd Gen SV
Miles Kms: 900000
i run k3 gsxr 1k on my sv. These are some awesome forks.
MotoTrackSide is offline   Reply With Quote
Old 08-21-2019, 09:56 AM   #6
fastegg
So you run this same f/e ?... How did you fit it up ?... What did you use for the stem/bearings etc ?... What fitting problems did you encounter ?... What year model your SV ?
Old 08-21-2019, 10:57 AM   #7
Junkie
Bikes: 06 1k
On a 1st gen you'll need a new top bearing in a funny size, and steering stops
On a 2nd gen the GSXR triples bolt right up. I'd recommend replacing the bearings vs mixing parts from 2 different sets of used bearings.
You'll need a GSXR wheel and rotors. Since you don't have radial mount brakes, you're stuck with 320mm rotors. 01-05 GSXR600, 00-05 GSXR750, 01-04 GSXR1000, any SV1000 front wheel works. 01-03 GSXR600, 00-03 GSXR750, 01-02 GSXR1000 rotors work.
I wonder what it takes to mount Yamaha blue dot calipers, they're a significantly better caliper (this would be off an R1 prior to 04, an R6 prior to 05, an R6S, or plenty of other bikes). If making a caliper adapter it might also be possible to run a different size rotor. I'd set it up for a 310, and then use an 06/07 or 08/09 GSXR600/750 front wheel - they're lighter than the early wheels (and 08/09 is lighter than 06/07).
06 SV1000: 06 600 forks, Penske triple, Carrozzeria wheels, TopYokes triple, upright bars, RCS19, R6 calipers, OSF rearsets, full M4, Monster seat on custom subframe, JW Speaker Adaptive headlight
Junkie is offline   Reply With Quote
Old 08-21-2019, 06:07 PM   #8
fastegg
I already have the 4 pot K3 calipers on my SV forks . I really want to keep using my 3" wide 250 Across wheel .. it has 290mm RGV rotors which i also would like to keep... Or perhaps the K3 Gixxer 300mm rotors might fit my wheel... Dunno yet...
I'm sooooooo happy to hear the bottom clamp will slot straight in.. that will save me an awful lot of drama... I know that just using the 3.5" K3 rim with it's large 22mm axle would slot straight in... brakes would fit...
.... Just wait'n'see.....
Old 09-18-2019, 10:51 AM   #9
fastegg
It's getting close... couldn't use the Gixxer headset mainly because I want upright handlebars... speedo mount... so I'm using a 1250 Bandit headset and bored the 43mm clamps out to 45... SV stem pressed right in (Bandit one was too long)... 1250 Bandit 310mm offset rotors with 3.8mm spacers to line rotors up perfectly with the calipers.. machined up sleeves that pressed into the fork axle clamps to accept 17mm axle but I've just purchased an RGV250 hollow axle as the SV one weighs heaps... Last job, we have to press a plug into the lower caliper bolt hole as the Gixxer had 320mm rotors (now using 310's) so we'll press in a plug then redrill it so the caliper is 5mm closer to the fork...
Guard is at the paint shop...
When all the machining is done I'll disassemble the lot and have all the alloy components vapor blasted....
....... Getting there.....
ID:	43927   Click image for larger version
ID:	43929   Click image for larger version
ID:	43931   Click image for larger version
ID:	43933   Click image for larger version
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
