2006 SV1000S 289 Actual Miles - Page 5 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > The Build Board
The Build Board A place to post a journal or log of your SV / Gladius projects and builds. No replies or discussion are allowed.
Reply
Thread Tools Display Modes
Old 12-31-2017, 09:59 AM   #41
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
Re: 2006 SV1000S 289 Actual Miles
Working lower triple clamp.
Cleaned out with steel wool. Chased threads and bolts. Waiting for bearing set. Suzuki make head bearing set that includes two bearings and dust seals, whole kit for bout 70 bucks delivered. Better deal than buying items separately. Waiting for delivery.
Lower bearing race looks pita to remove. Not sure if my home compressor will run my I&R air chisel, if so job will be quick....
EUROJulian is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-10-2018, 09:20 PM   #42
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
Got the bearing kit. Air chisel made a snap removing bearing race.
For installation I ground inner diameter of old race with sanding drum. Once hole opened up it went on the shaft without resistance. This old race become drivers head.
http://www.sv-portal.com/forums/albu...ictureid=12562
Next was pipe long enough to reach all the way down the shaft and 20t hydraulic press.
http://www.sv-portal.com/forums/albu...ictureid=12538
Old 01-12-2018, 01:37 PM   #43
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
Evotech tail job:
Evotech instructions are here:
http://images.cloudcommercepro.com/0...structions.PDF
Selected evotech because I wanted to retain tag light and oem turn signals. Evotech piece is kind of pricy at 100 bucks.
Just finished installation, not impressed at all. Oem turn signal Reinforcement bar didn't fit, self tapping hardware was not there for the upper plate. Instruction were sketchy. Mounting hardware for an merican tag are joke. There was no hooks to retain relay block. In short shyte.
Looks good though.
http://www.sv-portal.com/forums/album.php?albumid=1282
At the end I attached relay block to the seat latch bracket. Secured well, finally happy about its location
Old 01-14-2018, 12:21 PM   #44
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
I supposed to get last parts yesterday but I didn't. Boomer. Went fishing, cut nothing. Boomer. Better day today hopefully, test drove around nignborhood for a first time with new front end. Still faring is off and ignition switch not connected but bike runs fine on new forks.
Last parts are two cooling hoses that connect to thermostat housing and cylinders. I will dig to them and replace fuel filter with new one plus relocate ignition switch to left side. All one job I won't start unless I have all parts on hand.
http://www.sv-portal.com/forums/album.php?albumid=1290
Old 01-27-2018, 07:08 AM   #45
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
Finally our everything together and drove phase II bike yesterday.
Came out really nice.
http://www.sv-portal.com/forums/albu...ictureid=12634
More pics in swap album
http://www.sv-portal.com/forums/album.php?albumid=1266
I spent lots of time trying to place ignition switch and retain its full functionality. Finally I have workable design, just bit fabrication left to do.
First impressions: bike is quicker to turn, yet stable. USD Kayabas make better job over rough surfaces. TLS bars feel like SV stockers.
Old 01-27-2018, 07:51 AM   #46
EUROJulian
Member
Bikes: SV1000+2006
Miles Kms: 295
Those who follow from the beginning know that I made conversion to external Toyota pickup filter. Filters I get are inexpensive and quick connecting so replacements are snap.
http://www.sv-portal.com/forums/albu...ictureid=12618
With tank removed and all work associated with swap I took opportunity to replace fuel filter with new one. That is 3 rd filter I have changed since I cleaned the tank. All to the tune of 24 dollars delivered. Try to price that for factory junk design.
To have more room I am removing filter bracket attached to the filter, just keeping filter body
http://www.sv-portal.com/forums/albu...ictureid=12610
While at it I noticed connection to the fuel hose connector at the TB end developed a leak. IIRC manual suggests replacing fuel hose after 5 years in service, mine was overdue. Note that date of manufacturing is stamped into connector bodied.
http://www.sv-portal.com/forums/albu...ictureid=12626
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
