ABS on the '07s... - Page 3 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 04-04-2008, 11:55 PM   #21
misnblu
Re: ABS on the '07s...
Great read on the ABS and is one of the things I'd be ordering or buying once I get my SV.
The links were a great read and downloaded the MSF pdf files for further perusing.
I plan on an '08 model so I hope that the ABS feature will be available to me since I've not rode a bike in about 15 years.
MSF courses coming and then the purchase.
Thanks again for the read.
misnblu is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-20-2008, 06:06 AM   #22
deslock
Member
deslock's Avatar
Bikes: '08 SV650n (gray)
Thanks for the story. I wanted ABS but wasn't been able to find it anywhere... I got a good deal on a non-ABS '08, so I decided not to wait anymore.
The Suzuki dealers told me that people just don't want to pay $600 extra on a $6k bike for ABS. Seems like it's well worth it to me (especially since the '07 was an extra $1k).
deslock is offline   Reply With Quote
Old 05-04-2008, 03:55 AM   #23
kenwoodguy
Senior Member
kenwoodguy's Avatar
Bikes: sv650n
Miles Kms: 00
Send a message via Yahoo to kenwoodguy
what is the price on a abs model is it less then msrp at the dealerships??
kenwoodguy is offline   Reply With Quote
Old 05-08-2008, 10:31 PM   #24
bmewillow1985
Member
bmewillow1985's Avatar
Bikes: 2005 SV650s K5
Miles Kms: 10,400 miles
Send a message via AIM to bmewillow1985
Quote:
Originally Posted by ebrown0104 View Post
i'm glad everything worked out for you
but, did you really finance a $6000 bike over 5 years?
I did the same thing, I don't know how many years though when I bought mine new in 2005 I got some APR special and put $500 down and only pay $100 a month, but I did landscaping and it was seasonal so it worked for me. kinda does suck when you think about it... but ehh i got a bike to ride to w/e
bmewillow1985 is offline   Reply With Quote
Old 09-30-2008, 03:33 AM   #25
crazyhawk99
Member
Bikes: SV650, plus others
Miles Kms: 4600 miles
Quote:
Originally Posted by dangerismymiddlename View Post
The SVs ABS is so completely worth it. I have had that puppy kick in while leaned over on the track, and a few other times when I absolutely needed it. (Yes, real racers don't usually use their rear brake, while leaned over, on the track. I am a Track Day novice, and like all people, I make mistakes sometimes.)
[UPDATE 2008-08-21] As mentioned in y'all's comments below: the system works with both wheels. The ABS pump doesn't look like it is attached to the front brake lines, and the brakes aren't linked, and I never fealt it work in front, so I believed that it only worked in back, but I was incorrect. Rear-wheel lockups cause lowsides, so there would be some benefit even if it only worked in the rear, but I was incorrect nonetheless. Thank you for the comments. Here is a Suzuki video that demonstrates: http://www.suzuki-gb.co.uk/extra/000057/ [/UPDATE]
I have some of my thoughts about motorcycle safety here:
http://dangerismymiddlename.wordpres...les-part-deux/
http://dangerismymiddlename.wordpres...r-motorcycles/
http://dangerismymiddlename.wordpres...d-wing-airbag/
http://dangerismymiddlename.wordpres...untersteering/
http://dangerismymiddlename.wordpres...s-do-not-work/
Great links. Thanks for the info.
I would like to clarify that rear wheel skids/ lock-ups don't normally result in a "low side". Rear wheel lock-ups almost always lead to a "high-side" if there is a crash. And as we all know, a high-side is MUCH more painful than a low-side.
__________________
Current Bikes: 09 R1200GS, 09 Buell 1125CR, 04 ZX10R, 02 HD FLSTS, 03 SV650, 88 883 Sporster (cafe project); Previous Bikes: 71 KE100, 78 DT250, 84 900 Ninja, 87 535 Virago, 88 ZX10
crazyhawk99 is offline   Reply With Quote
Old 10-17-2008, 12:55 PM   #26
tk1971
Supporting Member
tk1971's Avatar
Bikes: 08 SV650A
Miles Kms: ???
While doing some general maintenance of tightening stuff up, I went ahead and traced the brake lines on my 08 SV N ABS.
The brake line from the front reservoir goes to a fitting on the frame connected to a hard line going to the ABS pump located where non-ABS models have their battery box. Another hard line goes from the ABS pump back to the front of the bike, where the hose connects it to the brake line to the calipers.
The rear is similar. The line from the reservoir goes to the ABS module and comes back to the caliper.
Just a thought... aftermarket SS brakelines may not work on ABS models.
tk
tk1971 is offline   Reply With Quote
Old 02-19-2009, 08:17 PM   #27
speedfrk
Member
speedfrk's Avatar
Bikes: 1985 Yamaha RZ350
Miles Kms: 3400
My abs light stays on all the time... any idea what to look for? Brakes work fine, but I'm hesitant to try the abs to see if it still works. Anyone else have any problems with their abs?
speedfrk is offline   Reply With Quote
Old 02-20-2009, 08:41 AM   #28
Vspec
Senior Member
Bikes: K6 SV650S
Miles Kms: Over 20K KM
tk
I don't see why not.
As long as you can replace the existing line with an SS of same length. On a car, when SS lines are installed, the hard lines are kept, only the flex line is replaced.
My LSL handlebar kit has a replacement SS line that goes from the MC to the fitting on the frame. I have to figure out how to disconnect it from the fitting and replace the line with the SS one.
One thing that I read in the Haynes manual that covers ABS models, I will require a vacuum pump to bleed/empty the system.
__________________
K6 SV650S-MotoSliders-Pilot Road 2-Sargent Seat-OEM Chin Spoiler-LSL handlebar kit
Vspec is offline   Reply With Quote
Old 02-20-2009, 09:25 AM   #29
mavfan
Senior Member
mavfan's Avatar
Bikes: 07 Suzuki SV650S, 04 Yamaha R1
Miles Kms: 35k miles
Quote:
probably is inoperable.
mavfan is offline   Reply With Quote
Old 02-20-2009, 09:49 AM   #30
tk1971
Supporting Member
tk1971's Avatar
Bikes: 08 SV650A
Miles Kms: ???
See this thread:
http://forum.svrider.com/showthread....&highlight=abs
It was covered under warranty. And, no, your ABS won't work, so don't try to lock up your brakes.
tk
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
no Powercommander or FI200r for '07s? 07SVinMS Motorcycle Talk 3 10-07-2008 12:45 PM
Adding ABS to non-ABS model SDRider Motorcycle Talk 40 07-07-2008 05:43 PM
Leftover '07s OTD price and other questions Skits Motorcycle Talk 9 03-15-2008 07:09 PM
ABS Repair - Anyone tried making an ABS putty? wi_sci SV Modifications and General Maintenance 13 02-26-2008 09:37 PM
ABS Or no ABS evochopperv21340 Motorcycle Talk 12 11-12-2007 02:24 PM
1999-2009 SVRIDER.com.
