Re-Mapping: PCIII, Teka, Yosh & Techlusion - Page 2 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 10-17-2007, 06:03 PM   #11
kwakr738
Senior Member
kwakr738's Avatar
Bikes: 2005 Suzuki SV 650N
Miles Kms: 4000
Send a message via AIM to kwakr738
Re: Re-Mapping: PCIII, Teka, Yosh & Techlusion
I had a D&D Full Exhaust installed without any tuning and it gave me 77.58 HP. I had a TEKA tune and ended up with 79.25HP. The bike runs smoother now. The CO2 measurements shows that the bike is not running lean, but actually running rich from 4-7k RPM. The engineer actually leaned it out significantly in this range. From 7-8k the engineer did richen the mixture with more fuel. Overall through out the rev range, the graph shows more leaning out of the mixture rather than increasing fuel.
__________________
~{kwakr738}~
kwakr738 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-17-2007, 11:34 PM   #12
kwakr738
Senior Member
kwakr738's Avatar
Miles Kms: 4000
FOR A FULL TEKA TUNE REVIEW
http://forum.svrider.com/showthread.php?t=58199
__________________
~{kwakr738}~
Old 10-18-2007, 04:43 AM   #13
MOTORCOP1104
Senior Member
MOTORCOP1104's Avatar
Bikes: SV650 SS SV650 SBK
thanks for sharing kwakr738. great info. With the oxygenated race fuel that Kris uses, I bet that rich spot goes away with the OEM ECU. That's a healthy SV, specially on a Factory dyno!
MOTORCOP1104 is offline   Reply With Quote
Old 10-18-2007, 08:24 AM   #14
kwakr738
Senior Member
kwakr738's Avatar
Miles Kms: 4000
Quote:
The bike is 2005 with about 3800 miles. I bought it 2nd hand from an owner that looked like he babied it. During the run, it had a stock intake and was running on a fresh tank of 93 octane. I have to be honest, I am somewhat skeptical of the results. I have read of people seeing 5-10% increase in HP going from an Eddy to Dynojet. Depending on how you calculate for loss, I can easily blow by HP numbers I have seen on this board. The important thing is that the bike runs smoother and there is an increase in HP after the TEKA tune. I am also happy to be able to provide my experience and results with a person considering this option. If there is another option out there with "proven" results, please post here:
http://forum.svrider.com/showthread.php?t=57886
P.S. Another reason may be yellow is faster than blue
__________________
~{kwakr738}~
Old 10-18-2007, 08:47 AM   #15
Kris87
Senior Member
Kris87's Avatar
dyno results can vary wildly. i really think they're only beneficial to see what kind of gains/losses can be made from changes on the bike. peak hp can be manipulated by the dyno/dyno operator. its quite easy. while i have no doubt this bike probably is running better after the tune, no way its making 79 hp with a stock engine and that pipe. my supersport engine with leo vince and the best race gas vp makes barely makes more hp than that. like i said, its all relative.
but on another note, i'm glad someone finally had proven dyno results to confirm that not all sv's are lean with a pipe. i told you it would be rich!!!!!!
__________________
Kris Wall Ex#87
2007 Wera Sportsman LWTSS, F2, D Sbk, Clubman National Champion
2009 Wera National LWT SS Champion
Kris87 is offline   Reply With Quote
Old 10-18-2007, 09:13 AM   #16
kwakr738
Senior Member
kwakr738's Avatar
Miles Kms: 4000
Kris!! My Bike makes more HP than your bike!! Yellow is faster than blue!! Just kidding. I am going to have to agree with you, I feel the numbers are pretty wild. Just so you know, I kept pushing with the service dept to get me those darn A/F ratios. The manager called his lead engineer who wasn't even working that day. As you will read on the other post where our wager was set, Eddy does not measure A/F. But the engineer clearly leaned out the bike on most areas for better HP. They did give me a bigger graph of the CO2 levels that I have yet to scan. But yeah, your right, this lean thing is based on assumption.
__________________
~{kwakr738}~
Old 10-18-2007, 02:11 PM   #17
kwakr738
Senior Member
kwakr738's Avatar
Miles Kms: 4000
Here are the CO2 levels. The original is in RED. The blue is how the engineer tuned for HP.
You can see where they lowered the levels of CO2 or leaned out the mixture.
__________________
~{kwakr738}~
Old 01-03-2008, 02:10 PM   #18
J-MANSV
P.S. Another reason may be yellow is faster than blue [/QUOTE]
BS. Blue and White will always be faster!!!!!!
J-MANSV is offline   Reply With Quote
Old 01-03-2008, 02:52 PM   #19
Demous
Senior Member
Demous's Avatar
Bikes: 01 suzuki sv650s/03 sv1000s
Miles Kms: 50k
ok then any one know where I can find the interface program for the PCIII. I did not buy it so I do not know if it comes with it or what>>?
Demous is offline   Reply With Quote
Old 01-12-2008, 12:04 AM   #20
Mr. Quick
Junior Member
Bikes: 04 SV 650S
Miles Kms: 7500
Lean from the factory? ? ? that makes no sense at all. They all run rich if anything. Have you ever thought about elevation? The factory engineers would never chance.
Mr. Quick is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Looking for TEKA or Yosh box to borrow in Mid Florida.... clm2112 SV650 Gen2 (03-15) Tech 3 10-13-2018 03:36 PM
Mapping PCIII. Unpredictable419 SV650 Gen2 (03-15) Tech 5 06-05-2010 06:39 PM
Re-Mapping???? jimmythe salmon SV Modifications and General Maintenance 0 05-16-2009 05:06 PM
OEM Suzuki EFI re-mapping??? Rock Dodger SV650 Gen2 (03-15) Tech 1 03-30-2009 08:40 PM
Silp-on Exhaust and re-mapping? skygodmatt Motorcycle Talk 2 03-22-2008 04:56 PM
1999-2009 SVRIDER.com.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
