Gas Tank Bracket Bolt Just Keeps Spinning - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Old 09-05-2019, 11:48 AM   #1
nocturnal305
Bikes: Suzuki Sv650s 2006
Miles Kms: 5K
I've been dealing with gas leaks and fuel pump assembly issues so I've had to get underneath the tank. This wasn't the first time I took the tank off and put it back on. However, this time, once I tightened the bolt (6x100) back into the bracket, it will not for the life of me come back out. It just keeps spinning like as if the threads are stripped. Now I know I did not torque it or put crazy effort into it, but its as though this bolt was ready to go. Now it just keeps spinning and spinning. Now, I can't get the tank off without either taking the bolts off that screw the bottom bracket into the frame or the top bracket to the tank; which is a two man job might I add. The hinge might as well be useless to me now.
Any one have any idea how to take this bolt off? I don't think this is a job for easy out extractor, but I could be wrong. At this point, it seems like I will need to get new bottom and top brackets, new spacer and new bolt just to be able to take my tank off like I should.
nocturnal305 is offline   Reply With Quote
Old 09-05-2019, 05:17 PM   #2
GeorgeRYoung
GeorgeRYoung's Avatar
Bikes: Suzuki SV650S 2003
Miles Kms: 60000 km
Re: Gas Tank Bracket Bolt Just Keeps Spinning
Not speaking from experience here, but I did have a look at a parts diagram.
If you can grip the bolt head with small vice-grips and pull on it while you twist counter-clockwise, it might come out.
If it does, and you don't mind being crude, you could drill the remaining threads out of the far side of the bracket, and use a longer bolt and self-locking nut.
Free advice, worth every penny, good luck.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 09-05-2019, 10:38 PM   #3
golden chicken
golden chicken's Avatar
Bikes: 2005 SV650n
Miles Kms: 58,000
Most likely you've broken the little spot welds on the nut on the other side. Just get some pliers in there on the other side and hold the nut still. It might be easier to take the tank off and the hinge off so you can bring it somewhere and weld the nut back on better.
Have a nice ride.
golden chicken is offline   Reply With Quote
Old 09-05-2019, 10:54 PM   #4
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Originally Posted by nocturnal305 View Post
... It just keeps spinning like as if the threads are stripped.
If the welds are broken on the nut then I would do as GC said.
If the nut is stripped then, as George said, you will need to put pressure on the bolt while unscrewing to help it turn it's way out.
For the "stripped case" it might be hard to get vice-grips in there to pull on the bolt. If not enough space, try push on the bolt from the other side. On my bike the end of the bolt sticks out about 1/4".
To push on the bolt the space is tight but a 2ft section of 1/2" dowel from Home Depot would fit in there. To get enough force on the dowel/bolt, maybe position the bike near a wall, set the dowel against the wall, push the bike against the dowel while unscrewing. If that makes sense. Good luck.
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Old 09-08-2019, 09:12 AM   #5
GeorgeRYoung
Miles Kms: 60000 km
Found a pic of the bracket. It looks like the nut is held in place by a clamp. If the nut is stripped, you can probably bend the clamp out and replace.
Click image for larger version
Old 09-08-2019, 12:02 PM   #6
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Good find, George. Third option to this is the clamp has poped up and not holding the nut well. If so, might be able to just push down on the clamp with a screwdriver.
I am interested now to see what the op finds out.
Old 09-09-2019, 12:52 AM   #7
nocturnal305
Miles Kms: 5K
Guys! Thank you so much for your input. So I ended up finding the lower and upper brackets on ebay, with the spacer and bolt for around 30$. Used but that's alright of course. I will just swap the whole set and that way this is easier. I tried prying with a flat crowbar every single way on the bolt end while turning the bolt head and nothing. Plus, previous owner had lost the spacer, I think this had a big factor to why this happened. Anyway, I will just have spare parts just in case.
Thanks once again fellow riders!
Old 09-09-2019, 10:31 PM   #8
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
How did you get the stuck bolt out? Curious minds want to know!
