HID/Projector INSTALL IN FIRST GEN - Page 2 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 02-11-2013, 09:17 PM   #11
JimmyTheMonster
Member
Bikes: 2002 Suzuki SV650S
Miles Kms: 5500
They should definitely be removable. Everything can be taken apart
JimmyTheMonster is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-11-2013, 10:11 PM   #12
Krygiel032
Member
Bikes: SV650s
Miles Kms: 14000
Re: HID/Projector INSTALL IN FIRST GEN
Sweet thanks
Quote:
Krygiel032 is offline   Reply With Quote
Old 02-12-2013, 10:14 AM   #13
phswrestler119
Senior Member
phswrestler119's Avatar
Bikes: 2000, Suzuki, SV677R
Miles Kms: Umm..... Not the slightest
Done this to a buddies subaru headlights. Bet its the same concept.
Linky
__________________
DISCLAIMER: Information posted by me in this forum is my opinion based on personal experience. We all make mistakes, so always double check.
phswrestler119 is offline   Reply With Quote
Old 02-12-2013, 10:50 PM   #14
Krygiel032
Member
Bikes: SV650s
Miles Kms: 14000
Yes it's similar in that doing the retrofit you bake the headlights and all that fun stuff, but in the case of the first gen sv's the lens itself is actually a textured plastic lens (refer to photo on page 1). So unlike the subarus which already have a clear lens, I'm gonna have to end up sanding it down to the point where it becomes clear. The retrofitting and all that isn't the problem, it's the sanding of the lens to hopefully make it clear.
Quote:
Linky
Old 02-13-2013, 09:34 AM   #15
phswrestler119
Senior Member
Quote:
If I'm not mistaken the parabolic ridges that you want to get rid of are on the inside. You will still need to separate the lens to sand those down. Also something to think about is the material the lens is made of. Depending on what type of plastic,and the process they used to manufacture it will dictate if you can even get it clear. Looking forward to seeing how it turns out. Good luck
__________________
Old 02-15-2013, 07:27 PM   #16
chewymilk99
Site Supporter
chewymilk99's Avatar
Bikes: 2002 sv650s
Miles Kms: 17,000
I installed the bkmoto kit for the 2nd Gen in my 02s and as far as better lighting for night riding. Its awesome. But I wouldn't suggest doing halos or anything, because of the texture of the lenses. You won't be able to see the halos clearly.
As far as polishing the lens. Don't try. You will ruin the plastic. I work in plastic manufacturing. During the formation of the raw material (plastic pellets) they add hardening and sealing agents into the mix.
When they melt that and form the plastic sheets that eventually get molded into the lenses.
The protective layers are microns think.
You will be able to grind off the ridges, and polish the lenses.
But it will haze on the inside in a few months (notice car headlights that are hazy)
There are headlight polishing kits you can buy that come.with a sealer.
But in all honesty. They suck.
If I were to do it again I would grab a second Gen headlight nacelles and see if I could get it kinda fit in the first Gen fairing.
Or I would have gotten some water proof hids and just cut the lenses off.
But check with whoever does your inspections. Because most states require a DOT # to be legal.
__________________
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
chewymilk99 is offline   Reply With Quote
Old 02-17-2013, 06:14 PM   #17
Krygiel032
Member
Bikes: SV650s
Miles Kms: 14000
Damn... I was hoping sanding them with some elbow grease would do the trick. I love HIDs becaues I ride alot at night.. I'm probably better off upgrading to a second gen lol. Would you happen to have any photos of how the lights look on your sv? Also maybe a photo with the lights facing a wall or garage door; I'm wondering how the textured lens effects the way the lights look. And is it 35 watt or 55 watt?
Old 02-18-2013, 08:00 PM   #18
chewymilk99
Site Supporter
Bikes: 2002 sv650s
Miles Kms: 17,000
Ummm pics? I'll have set up a photo bucket account first. But I went with the 35 because the 55 are kinda blue.
They have the same spread as the stockers (OK maybe a little farther) but man they are brighter.
If you do it I would suggest painting the reflectors black. I didn't and it makes it a little scattered.
And when I say a little I mean little.
__________________
Mark Twain
Old 02-19-2013, 09:09 AM   #19
Sojuuk
Member
Bikes: 2004 Honda VFR800
Miles Kms: 8500
Photobucket not required! http://minus.com/ allows anonymous uploading but does delete the pictures after 30 days I believe. I am also really interested to see how the lights look in use.
Sojuuk is offline   Reply With Quote
Old 02-19-2013, 08:03 PM   #20
Krygiel032
Member
Bikes: SV650s
Miles Kms: 14000
If did install them I'd definetly remove the reflectors because that's what the projectors are for. As far as 35 vs 55 watt, I installed both on multiple cars and the 55 watt ballasts tend to wash out the color of the bulbs, so you'd just choose a higher color temperature than you would if ordering the 35 watt. If i'd do it I'd go 55 watt, go big or go home
I'm just wondering how the textured plastic lens would affect how the HID+Projector lights look (with reflecters painted over).
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
