Suave's GSXR Swap Pictoral Guide. - Page 4 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 01-26-2009, 07:59 AM   #31
2001chromo
Member
2001chromo's Avatar
Bikes: 2002 sv650, 2001 Ducati M900, 2009 ZX6R
Re: Suave's GSXR Swap Pictoral Guide.
Quote:
Originally Posted by Jan Zoellner View Post
I wanted to do it this way, too. But with the very thin wall thickness of Zorans bearing it actually worked worse then tapping it in, so YMMW.
Ciao
Jan
+1
I tried with a headset bearing press the first 3 times and it kept going in too crooked.
I ended up just gently tapping it in with a mallet and the old race on top, this ended up working perfectly.
Then I did the bearing press just to make sure it was bottomed out and parallel.
2001chromo is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-26-2009, 12:07 PM   #32
SuaveNotion
Senior Member
SuaveNotion's Avatar
Bikes: Birthday Suit 2k
Miles Kms: As we speak
Another fix i used was after you have tapped the race in, place the bearing in and the dust cover and top nuts and lower triple and tighten them down super hard then back off of them to normal tightness. Seems to have helped center it a bit.
SuaveNotion is offline   Reply With Quote
Old 01-26-2009, 12:13 PM   #33
LSCYCLING
Supporting Member
LSCYCLING's Avatar
Bikes: 05 sv650n
Miles Kms: stuck at 24,210
ghetto subscription! looks like a great one to follow. Nice pic catalog.
__________________
Quote:
Originally Posted by frick View Post
Some ________ (plural noun)are too long for their ________ (adjective) partner without risk of ________ (verbal pharse)
or the fun of being able to go ________ (adjective). That's a major ________ (noun).
LSCYCLING is offline   Reply With Quote
Old 01-27-2009, 12:00 PM   #34
gjscott
Senior Member
gjscott's Avatar
Bikes: 02 SV650, 04 SV650S, 03 ZX636, 78 GS750.
Miles Kms: 8000 miles, 11,000 Miles, 10000 miles
Quote:
I would never do that, you could put indentation in the race and /or put flats on the rollers. You should never over tighten thrust bearings.
I've seen the damage when people do this.
gjscott is offline   Reply With Quote
Old 01-27-2009, 06:35 PM   #35
SuaveNotion
Senior Member
Finally! My upper triple came back from the machine shop. I had them place a piece of aluminum cut up to fit the recessed areas of the top triple. Then I had them tap and drill it so that the bolts would work. Looks really good...
Old 01-28-2009, 01:29 PM   #36
wdieck
Senior Member
wdieck's Avatar
Bikes: 2011 GSXR 750
Miles Kms: 750
Interesting way to do it.
__________________
2011 GSXR 750
wdieck is offline   Reply With Quote
Old 01-28-2009, 05:20 PM   #37
SuaveNotion
Senior Member
Ok so once you have your triple with mounted gauges and risers if you're doing handlebars, you can go ahead and screw the keyhole back on the triple using that stupid security torx tool.
Once that has been done, pull all of the cables and wires from the controls and clutch back through in between the forks and neck.
Then you can go ahead and put the triple back on the bike.
Tighten the pinch bolts and top nut with washer once you have lined up the forks up top.
Ok now I made the mistake of putting the handlebars on first and then trying to put the controls on...WRONG.
Slide the left mirror on and screw in the left control using that stub as the guide.
Something like this...
Same goes with the right controls.
So then you can tighten the handlebars down once you have them where you want them.
Now you can put on the brakes using the 2 screws on each side.
So it should look something like this...
Old 01-31-2009, 03:20 PM   #38
SuaveNotion
Senior Member
The end is near!
My spacers came today which means i can finally get the tire on..
Remember: If you just buy yourself a busa axle and wheel then you will not need spacers for this. Unfortunately I didn't know this until after I had bought the wheel and axle...
Anyway, take off the rotor bolts and remove the rotor so you can put your spacers on them.
Then pull out one of your brakes so the wheel goes on easier, and slide the axle through wheel and the axle spacer.
You can see the spacer here although its kind of a crappy pic...
Now tighten the axle down to snug and then tighten the pinch bolts. Then you can finally get the thing off the jack.
All I have left is to make the speedo work and find some way to mount the headlight. Hopefully the Wisconsin weather will have at least gotten above freezing...
Old 02-03-2009, 03:05 PM   #39
toezter
Member
Bikes: K5 GSXR 600
Miles Kms: 15k+ miles
Send a message via AIM to toezter
My heater went out last night. Having the brother-in-law stop by to check out the furnace. BUURRRRRrr.
I just got my risers, waiting on minibars. A friend of mine "wussed" out on drilling holes for my top triple.
Great write up so far.
__________________
K5 GSXR 600
99 Katana 600 RIP
toezter is offline   Reply With Quote
Old 02-06-2009, 10:59 AM   #40
acidjzaz
Junior Member
acidjzaz's Avatar
Bikes: SV650s
Miles Kms: 10000
Great write up thinking about doing this sv650s!!!
acidjzaz is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Where is the step-by-step gsxr swap pictoral guide? does it exist? vilago SVRider Motorcycling Forum 34 04-01-2011 10:51 AM
Suspension set up guide - what are good starting measurements / how-to guide? superwormy Racing Discussions 3 11-05-2010 09:08 AM
Suave's GSXR Swap Post SuaveNotion SVRider Motorcycling Forum 7 12-17-2008 11:58 AM
any pictoral how-tos on cutting down a factory exhaust can? wallymann SV650 Gen2 (03-15) Tech 7 11-14-2007 09:58 PM
My completed guide for gsxr front end swap gunluvS14 SV1000 (03-07) Tech 1 01-17-2006 04:41 PM
1999-2009 SVRIDER.com.
