Suave's GSXR Swap Pictoral Guide. - Page 3 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 12-18-2008, 04:37 AM   #21
Jan Zoellner
Senior Member
Bikes: SV 650 S
Miles Kms: 80.000
Re: Suave's GSXR Swap Pictoral Guide.
Quote:
Originally Posted by SuaveNotion View Post
So then i'll need 2 right? One for each rotor, then a separate spacer for the rim, correct?
I had 2 pairs made (reduced the impact of the setup cost and I planned to have a race bike anyway...). They gave me the cnc mill program along with it. If I can find it, iŽll post it here.
Ciao
Jan
Jan Zoellner is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-18-2008, 07:29 AM   #22
redmonkey
Senior Member
redmonkey's Avatar
Bikes: SV'99 at the mo I don't know
Miles Kms: about 76xxx kms
Send a message via MSN to redmonkey
Quote:
Originally Posted by D'Ecosse View Post
You have a 'Busa rim though redmonkey - that is NOT the layout for the GSXR wheel the OP is using
Using your drawing above:
ID = 100.2
PCD = 120mm - 5 x 10.5 x 72deg
OD = (ideally whatever OD of wheel hub is) - something around 140mm
Thickness - 3.5mm (1/8" would be OK)
I know i just wanted to provide a rough blueprint for him to go with if necessary never hurts :P. But also i believe the newer GSXR rims have 6rotor bolts on each side not 5 like the earlier Busas
__________________
My Twins keep trying to kill me.
redmonkey is offline   Reply With Quote
Old 12-18-2008, 09:27 AM   #23
SuaveNotion
Senior Member
SuaveNotion's Avatar
Bikes: Birthday Suit 2k
Miles Kms: As we speak
My gsxr wheel actually does have 5 bolts, so the template and the new measurements will work pefrectly :P
SuaveNotion is offline   Reply With Quote
Old 12-19-2008, 10:08 AM   #24
SuaveNotion
Senior Member
So since the forks are now wider apart, will a carbon fiber fender have enough give to be pulled 5mm apart or will it break? Otherwise will i have to make a bracket?
Old 01-23-2009, 09:51 PM   #25
SuaveNotion
Senior Member
Finally got the top bearing from Zoran today. So since this is the next step of my project, I'll continue on the "Guide". So after you have exposed the neck are of the bike and have the triples and steering stem off, it should look something like this:
the picture above is actually the neck shown from above without the race in it. To remove the race, go in from the bottom with a big ass punch, in excess of 12 inches.
You gotta hit it from the bottom using the milled notches supplied from the factory.
After some light tapping and some finesse, it will pop out.
Then you can take a look at the new bearing race and compare with the old one:
The stock race is on the right and the new one provided with the bearing is in the center.
As Zoran's instructions read, use the old race turned upside down to tap the new one into place. Here is what the neck looks like with the new race in.
Zoran suggests that you file the notches deeper for future removal of the race, but I have no intentions of ever taking it out again so i didn't bother. He also suggests that you file the seat for the race in the event that you may have a poor casting. Luckily mine was cast pretty well so i didnt need to do any filing whatsoever.
After that you can grease up the top bearing and put it in place.
Now if you have a set of 53mm forks and a set of 54mm lower triples like i did, it will be necessary to either purchase or fabricate a 1mm spacer to accomodate the gap. I simply purchased a set of shims from convertibars for 20-something dollars, but making your own will definitely be cheaper.
Unfortunately you can only buy a set of 4: 2 1mm and 2 2mm. I guess i'll have 2 2mm spacers for whatever i may need them for in the future....
Anyway, bend the shim lightly until you can fit it into the triple and press it against it to make its shape round.
Now getting the forks into the triples with the shims in is a real [email protected]$#%. Rolling them in and being extra careful not to scratch them will end up with part of the shim sticking out the top. Once you have the fork where you want it, i.e. matched up with the top triple, take a piece of wood shaped like a wedge and gently pound in the shim so it is flush with the fork.
Unfortunately my camera stopped working at this time so i dont have a picture for this but i will soon.
I'm waiting for the machined spacers for the wheel and rotors along with the top triple which i have had reinforced and drilled to accommodate bars and gauges. Hopefully I will have them done this weekend as it is the last thing i need.
Old 01-25-2009, 12:13 PM   #26
acer66
Senior Member
acer66's Avatar
Bikes: 00 SV650
Miles Kms: not enough
Cool thread, but imho you should have filed the notches out for Zoran`s race because you might have to take it out when it wears out or something.
__________________
Some parts I have for sale are found here and I have more stuff so please feel free to ask.
Get the good stuff for your SV from TWF/Zoran
acer66 is offline   Reply With Quote
Old 01-25-2009, 12:24 PM   #27
D'Ecosse
Titanium Member
D'Ecosse's Avatar
Bikes: 03 SV650S; Custom Triumph Daytona
Rather than knocking bearings in with a mallet, I prefer to pull them in.
A length of threaded rod through the stem, a couple of nuts & washers (with the old bearing shell as Zoran suggests) and just wind the nuts down and pull the bearings all the way in to seat.
When installing the stem bearing, same method but use a conduit pipe slipped over the steering stem - again just wind the nuts on and those transfer the pressure via washers and the pipe to the bearing & press it on the stem.
For those who go the SRAD triples route - what do you guys do about a fender?
One advantage of the GSXR triples is ability to use GSXR fender which is perfect mount & spacing.
D'Ecosse is offline   Reply With Quote
Old 01-25-2009, 12:38 PM   #28
acer66
Senior Member
acer66's Avatar
Bikes: 00 SV650
I actually used my park tool steering race press bicycle tool last time.
Was a little dodgy because I had to use all king of spacers and washers.
But next time I do it I make a custom spacer because it still worked pretty good.
__________________
Old 01-25-2009, 05:01 PM   #29
SuaveNotion
Senior Member
I'm going to use a Busa fender but i'm going to cut it up because its so **** ugly. It is wide enough and the holes are in the right place. I assume that it may be possible to actually mount a GSXR fender on the inside of the tabs on the fork, but maybe not because those tabs are thicker than 3.5mm.
Old 01-26-2009, 04:18 AM   #30
Jan Zoellner
Senior Member
Bikes: SV 650 S
Miles Kms: 80.000
I wanted to do it this way, too. But with the very thin wall thickness of Zorans bearing it actually worked worse then tapping it in, so YMMW.
Ciao
Jan
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Where is the step-by-step gsxr swap pictoral guide? does it exist? vilago SVRider Motorcycling Forum 34 04-01-2011 10:51 AM
Suspension set up guide - what are good starting measurements / how-to guide? superwormy Racing Discussions 3 11-05-2010 09:08 AM
Suave's GSXR Swap Post SuaveNotion SVRider Motorcycling Forum 7 12-17-2008 11:58 AM
any pictoral how-tos on cutting down a factory exhaust can? wallymann SV650 Gen2 (03-15) Tech 7 11-14-2007 09:58 PM
My completed guide for gsxr front end swap gunluvS14 SV1000 (03-07) Tech 1 01-17-2006 04:41 PM
©1999-2009 SVRIDER.com.
