Clutch questions - Page 2 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 10-16-2019, 11:52 AM   #11
RIDER675
Senior Member
Bikes: 07 track, 99 street
Re: Clutch questions
Quote:
Originally Posted by tovar View Post
Your 2nd gen clutch most like had worn out washer between outer and inner hub.
Clutch enters right side hole. It's normal for the rod to spin with the lever in?
Could be the washer, I did compare the thicknesses. When I swapped just the hub and washer the disengagement seemed to improve but it was hard to tell. Don't remember if the wheel spun or it clunked harder. The hub turns easy enough I guess, but far from spinning on its own.
Think ive ruled out the adjustment and cable routing, spent many hours just adjusting it.
RIDER675 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-17-2019, 12:20 AM   #12
Kyalami
Junior Member
Kyalami's Avatar
Bikes: 08 SV650 Race Bike
Miles Kms: 2200
Interesting - I just went through some similar if not exactly the same symptoms on my gen2 race bike. The clutch was not fully disengaging when I pulled the clutch (was sticking for a varied number of seconds before releasing) and so getting the bike to downshift was damn near impossible. Based on what you are describing, as others have mentioned, the first thing I’d check is that the cable isn’t jamming. If you’re confident that isn’t the issue, I’d check the cages carefully to see if something is sticking. I pulled the plates and after fiddling around I found some scoring on the cage where the plate flange fingers meet. What I ended up doing was carefully polishing the metal on the cage where the plates touch with 400 grit to reduce every bit of friction, and that did the trick. It works perfectly now.
For the record - my push rod spins slightly as well. I hadn’t heard about that being a problem (and since I made the above mods it shifts smoothly anyway) but I’m going to check that washer too.
Keep eliminating things one by one. It’s a very simple system so you’ll find it eventually!
Kyalami is offline   Reply With Quote
Old 10-17-2019, 12:23 AM   #13
Kyalami
Junior Member
Kyalami's Avatar
Miles Kms: 2200
One more question: assuming you have the bike on a rear stand, is the rear wheel spinning with any force (as in can you hold it still with your hand or no) when you pull the clutch in?
Old 10-18-2019, 12:17 PM   #14
RIDER675
Senior Member
Quote:
Interesting, my clutch doesn't start to release on its own though. The rear wheel doesn't even spin in neutral on the stand with the basket from gen1 so I found some dragging is due to gen2 basket or frictions, but ive tried sanding the basket where needed which helped but it looks good now. The used frictions I tried dragged worse.
Tried a conventional motorcycle oil, it caused more drag than rotella synthetic. Clunking into 1st and harder to disengage, while rotella was butter, but when warm I suspect the rotella was making the clutch pull harder, ill have to test this again to make sure it wasn't my hand.
Old 10-19-2019, 02:24 PM   #15
RIDER675
Senior Member
Confirmed rotella t6 and t5 cause the clutch to get much heavier at 200f. It must cause the clutch fibers to expand or stick. This is what I noticed on track that made it impossible to downshift. Makes a surprising difference to how quick the engine spins up, and no clunk into neutral though. I think it should work alright with a new basket or fibers and mc specific oil.
Edit: Did another oil change and found the other oil I tried acted similarly at 212f so the oil had no change, just didn't let the engine warm enough the first time.
Old 10-21-2019, 12:01 AM   #16
Kyalami
Junior Member
Kyalami's Avatar
Miles Kms: 2200
Okay... so since we are on the oil topic... how full are you filling it in the sight glass? Another thing I’ve learned in my short amount of time on the SV is that quantity matters. My RC51 clutch didn’t give a damn how full it was... on the SV if you fill it to the top, there is too much drag on the plates and it is harder to downshift. I run mine in the middle and it actually makes a big difference. I’m running Mobil 1 10w40 Racing 4 T... have also run the expensive stuff (Motorex) but didn’t notice a difference.
Do you know what detent spring you’re running on the Star shifter? Could also be that....
Old 10-21-2019, 11:46 AM   #17
RIDER675
Senior Member
Ive had the level between marks or slightly below, for sure it makes a difference. It could be since the plates were soaked in syn that it could take a while to be sure, so im doing a trackday and hoping it gets better as the plates soak.
Looked at the shift star spring but why would someone want to change that? I didn't think that could effect the lever pull.
Also the new clutch cable is almost out of adjustment for slack at the engine. With the adjuster at the bar in fully, at the engine adjuster the bottom lock nut has no more threads available to remove slack.
Old 10-28-2019, 11:38 PM   #18
Kyalami
Junior Member
Kyalami's Avatar
Miles Kms: 2200
Weird. Yes - the detent has nothing to do with the clutch pull... it affects how fast the gears engage when you activate the shifter.
Just as an FYI... here are some shots of my worm gear and cable position...
Click image for larger version
ID:	44187   Click image for larger version
Old 10-30-2019, 11:14 AM   #19
RIDER675
Senior Member
Looks like it was the oil after all, clutch felt great on track. Ill swap all the old parts back in and report back.
Old 11-14-2019, 12:48 AM   #20
Kyalami
Junior Member
Kyalami's Avatar
Miles Kms: 2200
Fantastic. Glad you figured it out! Oil is finicky in SV’s apparently... especially under track/race conditions...
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
