I need a fuel pump relay - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 09-11-2019, 08:03 AM   #1
Jay Bless
Junior Member
I'm looking for a fuel pump relay for 05 sv650 in Louisville, Ky
Jay Bless is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-11-2019, 08:06 AM   #2
Jay Bless
Junior Member
Will an 07 work on my 05
Old 09-11-2019, 09:19 AM   #3
MotoTrackSide
Member
MotoTrackSide's Avatar
Bikes: 2nd Gen SV
Miles Kms: 900000
Re: I need a fuel pump relay
yes. whats exactly is happening to the pump?
MotoTrackSide is offline   Reply With Quote
Old 09-11-2019, 09:32 AM   #4
Jay Bless
Junior Member
I get a 1 second prime and nothing else when I turn killswitch on it's the only thing that was "tampered with"
Click image for larger version
Old 09-11-2019, 09:32 AM   #5
Jay Bless
Junior Member
Also discovered it's an SV650K5
Old 09-11-2019, 09:52 AM   #6
Jay Bless
Junior Member
Went ahead and ordered the part. Hope that's the issue and then I can focus on getting the wiring cleaned up
Old 09-11-2019, 11:47 AM   #7
MotoTrackSide
Member
Bikes: 2nd Gen SV
Miles Kms: 900000
I went through a few trial and errors troubleshooting my fuel pump. I am on my 3rd one which is from a k8 and k6 throttle bodies. I will find out this Saturday if it's a go on circuit.
Old 09-11-2019, 11:57 AM   #8
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Quote:
My apologies, Jay. My poorly worded reply in the other thread (now edited) makes it sound like I am saying the fuel pump relay is bad. Most likely the relay itself is okay. What I meant to say is the hacked wires to the relay are the likely problem, not the relay.
Where did you order the part from? Please try to cancel, send me a PM, I will reimburse you for any money lost.
Good first step to find the problem is remove the tape from the hacked wires and inspect the connections. Disconnect the battery when exposing the wires as the Red/White wire has constant power even with the key "Off". There is a good chance a flaky connection on one or more of the hacked wires is causing the C41 problem.
If still seeing C41 after inspecting/fixing the fuel pump relay wires then a few electrical tests can be done to isolate further.
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Old 09-13-2019, 06:55 AM   #9
Jay Bless
Junior Member
What would be the easiest way to remove the wiring from the connector so I can fix it right without an entirely new harness
Old 09-13-2019, 10:30 PM   #10
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
You have a few options:
1. Solder then cover with heat-shrink. Here is a good how-to video. You will need proper tools, some experience would be good.
2. Use Wirefy Solder Seal Butt Connectors. Only need a heat gun to use but given how close the four wires are it would be difficult to properly apply heat (need to rotate the wire to get to all sides) and might do damage to adjacent parts given the tight space.
3. Butt crimp connectors. These are generally a bad idea, especially if using the cheap autoparts store kits. Crimps are excellent if done properly (all the SV650 harness connections are crimped) but it is easy to get wrong. Only do crimps if you have a professional ratcheting crimp tool with wide-crimp dies, high quality matching crimp parts and prior experience.
4. Replace the harness. It is labor intensive but something you can do yourself without special skill. $50 for a used harness on eBay, guaranteed good connections. I know you said you do not want to do it but this might be your best bet.
5. Have a reputable shop do the repair.
Keep in mind several things can cause an SV650 C41 error. Based on the looks of the existing repair there is a good chance the problem is there but no guarantee.
Have you taken the tape off the wires? How does the repair look underneath? Best to understand what you currently have before going further.
Good luck.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
