How To: Automatic Timing Retard Eliminator (aTRE) - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > FAQ Section > Electrical
Electrical Lights, Resistor Rectifier, Wiring Harness, etc
Closed Thread
Thread Tools Display Modes
Old 08-23-2007, 12:07 PM   #1
volengineer
Senior Member
volengineer's Avatar
Bikes: Velociraptor
Using the basic idea from SV650.org TRE mod, you can create a smart TRE. This one electronically switches off in neutral to make cold starts not a problem as with just a resistor eliminating the circuit. (You may experience the neutral light being on very dim even when not in neutral, it is usually only noticeable at night. Not bright enough to see in daylight. This is normal to this circuit.)
Installation of the single resistor from SV650.org as reference for installation:
http://www.sv650.org/sv_faq.htm#How%...d%20above%20SV
and this image to create the electronic switch circuit:
volengineer is offline
Sponsored Links
Advertisement
Old 09-14-2007, 01:08 PM   #2
dbrowdy
Senior Member
dbrowdy's Avatar
Re: How To: Automatic Timing Retard Eliminator (aTRE)
Awesome!! I was going to try to figure this out on my own, but this is much easier. Thanks so much!
One question: my electronic engineer friend is going to be helping me do this. He wanted to know the amperage or wattage needed for the resistors or something. Any thoughts?
Thx,
D
__________________
Quote:
Originally Posted by Currently
Ignorance can be cured with knowlege ... stupidity on the other hand is terminal.
dbrowdy is offline
Old 09-16-2007, 03:07 AM   #3
dbrowdy
Senior Member
dbrowdy's Avatar
Sorry for the double-post. We got it all figured out. The circuit works perfectly! Thanks a lot for sharing the specs. I was worried I'd have to figure it out on my own.
BTW, I like the way you used the neutral light to detect neutral instead of the gear indicator. Slick solution to the problem.
I wish I had pics of our TRE, it looked pretty pro when we were done with it.
D
__________________
dbrowdy is offline
Old 09-23-2007, 12:06 AM   #4
daleo
Junior Member
Bikes: 2005 sv650
Miles Kms: 3000 mi
is the signal to the neutral light 12V
daleo is offline
Old 09-23-2007, 12:31 AM   #5
dbrowdy
Senior Member
dbrowdy's Avatar
I never checked...
__________________
dbrowdy is offline
Old 09-28-2007, 09:17 AM   #6
volengineer
Senior Member
Bikes: Velociraptor
yeah daleo, you are using the neutral light to determine when to turn the circuit off.
Old 09-28-2007, 07:43 PM   #7
daleo
Junior Member
Bikes: 2005 sv650
Miles Kms: 3000 mi
what years of 650s does this work on & is this the same on sv1000 also
daleo is offline
Old 09-28-2007, 10:59 PM   #8
dbrowdy
Senior Member
dbrowdy's Avatar
This is for the Gen2 SV650 (03+). The TRE mod for Gen1 is slightly different so I don't know if the aTRE will work. I'm shure it could be made to work but figuring out the wiring would be the trick.
I have not looked into doing a TRE on the SV1000. If the basic TRE mod works the same as the basic TRE for the gen2 650, then it should work fine.
__________________
dbrowdy is offline
Sponsored Links
Advertisement
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
