Gummy Carbs? How to clean? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > SVRider Motorcycling Forum
SVRider Motorcycling Forum Our main message forum catering to the Suzuki SV and general motorcycle chatter.
Reply
Thread Tools Display Modes
Old 07-12-2007, 11:25 PM   #1
xplatem1
Member
OK,
Saw are real sweet red '01. Only about 900 miles. Fellow said he left the gas in it and the carbs are probably gummed up. Understand it cost about $350 to get them cleaned and re set.
Is this a big job? Is this something a novice can do? Are there any links that show how to clean out the carbs?
My buddy said his bike was running bad but that it was an air leak from seals "drying out". Cost about the same to get it corrected.
Help.
I would like to buy this bike but really would like to fine a cheaper way to get it right.
x
xplatem1 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-13-2007, 01:59 AM   #2
NiceGuysFinishLast
Senior Member
NiceGuysFinishLast's Avatar
Bikes: '03 SV650S Copper, '02GS500 (For Sale!)
Miles Kms: 8900
Send a message via AIM to NiceGuysFinishLast Send a message via MSN to NiceGuysFinishLast Send a message via Yahoo to NiceGuysFinishLast
Re: Gummy Carbs? How to clean?
carbs are an easy, novice job, as long as you take your time and do it right. Go slow.. if you think things are going really well.. slow down, cuz you're about to do something stupid.
__________________
'03 SV650S Copper - Yosh RS3 CF Slipon - Flushmount Front Signals - Competition Werkes FE w/ Flushmount - Custom Scratches and Bent Rearset from Lowside
Coming Soon - Racetech .85 Springs w/ 15w oil - GSXR Rear Shock - Tires
NiceGuysFinishLast is offline   Reply With Quote
Old 07-13-2007, 08:22 AM   #3
Ruefus
Senior Member
Ruefus's Avatar
Bikes: '02 Silver SVS, '08 KTM 690 SMC
Miles Kms: Not enough for my liking
I hate to throw a bit of cold water on things......but I think this is the truth:
An '01 with 900 miles is going to end up having more issues than fermented carbs. Take a long hard look at anything rubber. Hoses, fittings - TIRES. Look for any cracking to indicate dry rot. These things are MEANT to be used - not sit in some garage, neglected to the point of no-start fuel issues.
Unless its been replaced - it'll need a battery before too long. Those don't care to sit unused either. Electrical gremlins pop up for no reason....the list goes on. I'd knock 500 bucks off whatever he's asking for the simple fact that you'll have to spend ~300 bucks to get the carbs sorted, and leave a few bucks leftover for 'issues'.
After watching supposedly 'cherry' low-mile bikes that are several years old roll through the shop the last two years - when I saw the words " '01 " and "900" miles referring to the same bike - I cringed. Add the gummed up carbs and the bike has been sitting somewhere for a LONG time.
It's probably really nice - but don't believe for a second that there aren't other non-use/age related issues waiting to rear up. The owner won't agree and will cite the 900 miles as a reason to charge more. Hogwash - I can show you numerous examples of nice, very expensive cars that were garage kept and run only once or twice a year. Nearly every time they got started - something was wrong. Stupid - little things, whereas the same model daily-driver had only normal periodic issues.
Whoever bought that bike and let it sit for so long should be smacked in the face - really, really hard.
__________________
Aerostich and Arai Fanboy......for obvious reasons:
http://ruefus.wordpress.com
Quote:
Originally Posted by Ruefus View Post
Just to be consistently hypocritical.
Ruefus is offline   Reply With Quote
Old 07-13-2007, 08:25 AM   #4
ronin_01r1
Senior Member
ronin_01r1's Avatar
Bikes: currently 3
make sure they didn't swap out the odometer!
__________________
SONG.
2007 Kymco Grand Vista 250 / 2006 KTM 950 Supermoto / 2001 Yamaha R1 / 1976 Honda CB 360t
ronin_01r1 is offline   Reply With Quote
Old 07-13-2007, 08:44 AM   #5
cantseejack
Site Supporter
cantseejack's Avatar
Bikes: In Pieces
Ruefus tells the true word. I got an 01 with about 4k (which is way more than 900 miles) and the guy had let it sit for the past year and there were a number of things that I had to do. The brake fluid was totally nasty and needed to be replaced. The brake hoses seem squishy and probably need to go, the carbs weren't as clean as they might have been and so it had this problem with keeping an even idle. The battery was acting a b*tch for the first few months but then it was okay and still is. I'm probably going to replace it this season.
BUT, maybe you can consider all this as fun to be had and learning about your new bike. That's how I looked at it and I don't regret my purchase.
__________________
01 SV650
03 Z1000
cantseejack is offline   Reply With Quote
Old 07-13-2007, 09:13 AM   #6
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
Miles Kms: ODO 97922
Humm here's a short list of things to be cleaned, inspected and/or replaced.
cleaning the fuel tank, fuel filter, fuel pump, fuel line
carbs, and vacuum hoses.
coolant fluid, coolant reservoir, radiator hoses
oil, oil filter
spark plugs, plug wires
brake fluid, brake lines
tires, fork oil, battery, chain
lube axles, wheel bearings, swing arm, control cables, steering stem and any moving pivot point.
/list
So as ruefus said, I'd factor in ALL these items into the price of the bike. That's one hell of a list of things to replace and clean and the parts cost is going to be over $400-$500 when you add in the tires. And if you're not able to change your fork oil or bleed your own brake and take it too a shop factor in labor hour rates around $68-$72 at standard book hourly rate.
Good luck!!!
__________________
I'm going to take my time
I have all the time in the world to make you mine
It is written in the stars above...Depeche Mode
Nexus242 is offline   Reply With Quote
Old 07-13-2007, 09:28 AM   #7
NHSVnaked
Senior Member
NHSVnaked's Avatar
Bikes: 2003 SV1000S
Miles Kms: 0 so far
Send a message via AIM to NHSVnaked
If you are a noob and you want buy this bike I wouldnt pay more than 2300. Then get a guy on the board to help ya do this stuff yourself. Thats the way to do it.
__________________
2003 SV1000S
1999 Triumph Daytona 955i(sold)
2002 SV650 (totalled)
NHSVnaked is offline   Reply With Quote
Old 07-13-2007, 09:34 AM   #8
GDI
Member
I bought my '01 in late '05 w/ 5700 miles. It had sat for at least a year with very few miles put on. I replaced the battery after it stranded me one very cold and rainy night (if you can push start one of these you have my respect). I also replaced the coolant right away. One of the lines to the coolant overflow was clogged, so it definitely needed changing. Surprisingly, the carbs weren't all that bad. I did pull them and go through them. They had only minor amounts of grunge. . . .
GDI
__________________
'00 Honda ST1100<br />'01 Suzuki SV650 (naked!)
GDI is offline   Reply With Quote
Old 07-13-2007, 07:43 PM   #9
xplatem1
Member
Thanks guys. I really feel good now. I was worried about gremlins and wondering if I really should. I have a bud that is going over with me tomorrow to take a look.
I still may end up buying it. My problem was not knowing what to expect. Now that I have your education and advice, I can make an offer accordingly.
I am going to post a seperate questions asking for detail carb cleaning instructions. If anyone has a link, it would be most appreciated.
Thanks
x
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
