Ignition Switch Wiring - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 07-06-2007, 09:18 PM   #1
Daddy_X
Member
Daddy_X's Avatar
Bikes: 2006 SV650S
I have an 06 650S and I'm trying to figure out the ignition switch wiring. I tried to take it off and use a meter but one of the torx heads is stripped, errrr. The wiring schematic was not much help to me either. Anway there are 4 wires leading to the switch, B/R, O, O/R and Br. I need to know which one of these is hot ONLY when the ignition is turned to ON. Thanks in advance
Daddy_X is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-07-2007, 01:51 AM   #2
Krautwagen
Member
Krautwagen's Avatar
Bikes: '07 SV650n
Miles Kms: 9700
Re: Ignition Switch Wiring
Sorry, I tried looking into the downloadable service manual, and there are no wiring diagrams - on that note, can somebody post up the US-spec wiring diagrams for us
But, there is some info in there as far as the kill switch...
__________________
Dave
'07 SV650 Nekkid
Krautwagen is offline   Reply With Quote
Old 07-13-2007, 06:56 AM   #3
gearman
Senior Member
gearman's Avatar
Bikes: '05 YAMAHA FJR1300
What are you trying to power? If it is low current draw, you can wire the hot straight to the battery (fused, of course) and the ground to the side stand switch (Green). You could also tap into the headlight circuit. As far as I can tell, red is the input for the ignition switch and orange is output for the starter relay, coils and ECM.
__________________
'05 FJR1300............Former SV haver............Too shy to ride naked
gearman is offline   Reply With Quote
Old 05-30-2012, 07:18 PM   #4
Jackstand Johnny
Senior Member
Jackstand Johnny's Avatar
Bikes: 00' SV650 Streetfighter
Miles Kms: 16,xxxish?...I don't have gauges.
I'm posting in this dead thread to for future reference for others. gearman is wrong. The red wire is not the only hot wire. It is the constant + for the ignition. I am still searching to find which wire is given power only after the key is turned to the "on" position.
Jackstand Johnny is offline   Reply With Quote
Old 05-30-2012, 07:49 PM   #5
RMAN
Senior Member
Bikes: '05 Triumph Thruxton 900 SOLD, Triumph T595 Daytona, '01 SVS SOLD
Miles Kms: 15,600 15,500 22,000
You have a 1gen not a 2nd gen so wiring is probably different. According to the wiring diagram for the 1gen, there should be 6 wires to the ignition switch. R is power from the main fuse at the relay. Gr appears to power the gauge illumination lamps which would only be on with the key, as well as the horn and maybe rear brake switch. Br powers the license plate lamp, position lamp for S models and the taillight which would go on with the key set to Park. O/R goes to the ignitor. B/W is ground, which leaves O which at least seems to go to the dimmer switch.
If you are looking for power with the key in the On position, I would test the Gr wire and then maybe the O wire.
RMAN is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
