Rear Axle Torque - Page 2 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 05-06-2006, 07:56 AM   #11
2 BLU
Member
Re: Rear Axle Torque
Isn't 45ft/lbs for the front tire?
2 BLU is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-06-2006, 12:00 PM   #12
andyauger
Supporting Member
Bikes: 2001 SV 650
The correct rear axle torque for first generation bikes is 47 ft-lbs, 65 N-m. That's both the owner's manual and the shop manual. I doubt that the identical typo would appear consistently in both publications.
andyauger is offline   Reply With Quote
Old 05-07-2006, 01:25 PM   #13
TWF
Guest
Posts: n/a
72.5 is correct for second gen.
axle is bigger than 1st gen,which is 47.
torque is dependent on size and grade of bolt.
you can find whole page of torque settings in back of service manual.
Old 05-23-2008, 06:03 PM   #14
pearsonm
Member
Bikes: F4i (track)
I've been using 100 NM per the manual, but man that seems tight. It's warping the washer behind the axle nut as well as the chain slack indicator.
__________________
You can't win a track day, but you sure can loose one.
pearsonm is offline   Reply With Quote
Old 05-24-2008, 12:44 AM   #15
saberworks
Member
Bikes: 03 SV650
I torqued mine to 72.5 and had no problems at all. Actually my torque wrench only does whole numbers, so we put it at 72 then had to tighten it a tiny bit more to get one of the cotter pin holes to line up.
saberworks is offline   Reply With Quote
Old 10-03-2008, 02:18 PM   #16
warrenpridgeon
Member
warrenpridgeon's Avatar
Bikes: 2003 SV650S
Miles Kms: 12000km
How important is it to torque it up?
Apparently on a buell you have to make sure it is at the right torque....
But for an 2003 SV650S...how important is it to be torqued exactly right?
I hear most of the tyre places don't even use a torque wrench when they pull your wheel off to replace the tyre...
somebody? anybody?
warrenpridgeon is offline   Reply With Quote
Old 04-15-2009, 09:05 AM   #17
masterp
Member
masterp's Avatar
Bikes: 2005 SV
I am confused on the proper rear axle torque for a 2005 model. The manual says 100 nm. The 2nd generation Haynes book says 65nm. The consensus is 72.5 ft/lbs is correct. I believe that roughly translates to 98nm. Others have said 100nm is way too tight. So I should set the torque wrench to??
masterp is offline   Reply With Quote
Old 04-15-2009, 12:15 PM   #18
andyauger
Supporting Member
Bikes: 2001 SV 650
The difference between 98 Nm and 100 Nm is 2%. Even freshly calibrated click-type wrenches have that much variability. Add to that axle and nut variability make that 2% meaningless.
Set for 98 Nm 2nd gen.
Old 04-15-2009, 02:50 PM   #19
Klyftonite
Senior Member
Klyftonite's Avatar
Bikes: 2009 Kawasaki ZX-6r, 2003 SV650s Copper
Miles Kms: 5000+
Send a message via AIM to Klyftonite
my service guide said 725 lbs, it puzzled the crap out of me lol
Klyftonite is offline   Reply With Quote
Old 04-15-2009, 03:01 PM   #20
masterp
Member
masterp's Avatar
Bikes: 2005 SV
It is confusing. I guess the bottom line is 72.5 lbs is correct. I bought my torque wrench, check the specs and get 3 different answers. I was all ready to do some maintenance. Thanks for the help.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
