1/4 mile and 0-60 times - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > Racing Discussions
Racing Discussions **POTENTIAL SPOILERS INSIDE** Discuss racing SV's - or talk about your favorite racers, from MotoGP to the local club circuit.
Reply
Thread Tools Display Modes
Old 01-03-2006, 11:28 PM   #1
mikrace
Senior Member
Bikes: 2006 SV650S, 2004 CR450F, 2011 BMW S1000RR
Miles Kms: 44,000+ miles
I recently bought a 2006 sv650s and installed a Veypor performance gauge. The Veypor gave me a way to do some 1/4 mile runs and 0-60 runs and I have no idea if they are slow or fast for a stock bike, so any opinions or suggestions would be appreciated since I am interested in the racing side of sportbikes. My best 1/4 mile run was 11.73 seconds and my best 0-60 time was 3.89 seconds, plus my top speed so far is 137mph. Do I need lots and lots of practice, or are those times decent for a stock bike
__________________
ASMA #171
"Fortune favors the prepared mind."
mikrace is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-04-2006, 08:58 AM   #2
Nimbus
Senior Member
Nimbus's Avatar
Re: 1/4 mile and 0-60 times
I'd say it needs to be calibrated. A stock SV650 will not do 137mph. The 1/4 mile time is faster than what CW has reported for the 2nd gens. The first gen in a '99 write up was measured at around 11.89/112mph and 3.7 0-60.
__________________
Says my wife after witnessing my first knee dragging: I've never seen you so excited about defiling your gear, usually you'd just swear a lot if you scuffed something.
Nimbus is offline   Reply With Quote
Old 01-04-2006, 09:09 AM   #3
Nudist
Senior Member
Nudist's Avatar
Bikes: SVeeeeees
My best 0-60 was 3.04 seconds
__________________
Nate CCS/ASRA #29 - www.nudebikesracing.com - Ticket2Speed, RnR Cycles, Twin Works Factory, Pro Speed Racing Apparel, Scorpion Helmets, Vortex, DC-Moto.net/Amsoil, Dunlop, DCSportbikes.net
Nudist is offline   Reply With Quote
Old 01-04-2006, 10:48 AM   #4
mikrace
Senior Member
Any other opinions on top speed or is Nimbus right The Veypor and the regular speedometer both said 137mph, and on the run before it, I got upto 133mph according to the gauges, so is there a problem with the bike or are the 2006's the fastest stock SV650's made??
The Veypor might need some minor adjusting to make the 1/4 and 0-60 times more accurate.
__________________
ASMA #171
Old 01-04-2006, 12:00 PM   #5
wonderjosh
Senior Member
wonderjosh's Avatar
Bikes: RSV1000 Mille
Miles Kms: not enough
Quote:
If 0-60 times are off, then everything is
__________________
Buy this stuff: TWF F3 spacer kit, Honda F2 Rear Wheel, Honda F3 Sprocket Carrier/Hub, 03 dash plastics, 03 SVS rear-sets w/gsxr footpegs
wonderjosh is offline   Reply With Quote
Old 01-04-2006, 12:50 PM   #6
mikrace
Senior Member
I tried doing some online searches to check the numbers and it seems my 1/4 mile and 0-60 times are average. I was guessing that the Veypor might need to be cal'd but it should be good. The problem is that I couldn't find anything on the top speed for a SV650S newer then 2003. The fastest was one site that said the 2003 has a top speed of 133.9mph. So that still leaves the question of what the top speed is for a SV650S newer then 2003.
__________________
ASMA #171
Old 01-04-2006, 01:46 PM   #7
eeeeek
Member
If your Veypor is pulling info from the SV's speedo, then all but the 0-60 are going to be off by a bit. At best, the speedos are off by 5-10% at higher speeds. An indicated 139 would more likely be sub 130.
This is not just an SV thing, almost every speedometer on every bike is less than accurate. The reason your 0-60 times may be right is the speedos are usually calibrated to be accurate around 55-65.
__________________
Vik AFM #64
Z Track Days
eeeeek is offline   Reply With Quote
Old 01-04-2006, 02:13 PM   #8
Honda_Fan
Senior Member
Honda_Fan's Avatar
Bikes: Honda ST1100
snip
See if you can get your hands on a GPS unit to check your speedo. All my bikes are off to some degree. The wife's SV is off about 3-4 MPH at 60 MPH. The GPS works best (most accurate)when cruising at a steady speed. It will vary quite a bit with the speedo when accelerating quickly. Nice thing is that on mine you can store your top speed so if you are doing a speed test on a controlled course, ridden by a professional (wink, wink) type thing you don;t have to worry about watching the unit for top speed. Again I am not condoning this type of behavior but the unit is capable of it.
Honda_Fan is offline   Reply With Quote
Old 01-04-2006, 02:43 PM   #9
mikrace
Senior Member
Thanks big time for the information Honda Fan and eeeeek. Since this is my first streetbike, I didn't know that speedometers are less accurate the faster you go with a sportbike. Everything makes sense now since my 0-60 time was the closest to normal but my top speed was high for this bike. I was starting to think there might be a problem with the bike. Thanks again.
__________________
ASMA #171
Old 01-04-2006, 09:16 PM   #10
evilbologna
Site Supporter
evilbologna's Avatar
Bikes: Naked CBR600RR
Miles Kms: -4
Quote:
Originally Posted by Ivan
I never did understand "corrected" 1/4 mile times. I think that just means they knocked off a second or two to make it look like they have bigger balls.
Pretty much.
__________________
The laws that keep us safe are the same laws that condemn us to boredom.
evilbologna is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
