TRE mod = Must Do! - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 09-17-2004, 07:55 PM   #1
Strick
Member
Strick's Avatar
TRE mod = Must Do!
I just completed the TRE MOD, maybe 10 minutes start to finish including tool prep. Once again, a MUST DO. I can feel the difference, and hear the difference.
Some here have mentioned the increase in MPG, but I can tell you that my bike feels stronger in 2nd & 3rd in the mid range. It goes through the RPMs in the formerly affected range much quicker. Also, on deceleration you can hear a lower (rumble) exhaust note.
Call me crazy, but this is the first mod I would do to a first generation SV.
I remember one guy on here getting beat up because he said he felt the gain on top. Well, we all know that the upper rpm range is not affected. However if you pull through the mid in 2nd & 3rd gear quicker (and you do!) then it will feel that the top is stronger (although it is not).
__________________
Strick
'01 SV650 - had - '04 Honda CRF450
'67 Camaro 408SBC
Strick is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-17-2004, 08:55 PM   #2
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
Miles Kms: ODO 97922
TRE mod = Must Do!
Ese what is this TRE MOD you speak of?? :?:
__________________
I'm going to take my time
I have all the time in the world to make you mine
It is written in the stars above...Depeche Mode
Nexus242 is offline   Reply With Quote
Old 09-17-2004, 08:56 PM   #3
Cavi
Member
TRE mod = Must Do!
excuse the newbie ignorance, what is the TRE mod?
Cavi is offline   Reply With Quote
Old 09-17-2004, 08:56 PM   #4
John Westcott
Junior Member
TRE mod = Must Do!
Check out tips and tricks.
__________________
Johnny Thrasher
John Westcott is offline   Reply With Quote
Old 09-17-2004, 09:28 PM   #5
Nexus242
Supporting Member
Nexus242's Avatar
Bikes: sv650
TRE mod = Must Do!
Quote:
and it would be where on that page??
__________________
Old 09-17-2004, 11:26 PM   #6
Strick
Member
Strick's Avatar
TRE mod = Must Do!
http://www.sv650.tk/
Check it out above. enter the site and click on mods.
Here is the topic in the 'tips & tricks' section here under gauges/electrical:
More Power - How to Disable the Ignition Retard Mechanism on the SV
The link has step by step pictures.
__________________
Strick
'67 Camaro 408SBC
Old 09-18-2004, 12:20 AM   #7
Yellow Nudist
Guest
Posts: n/a
TRE mod = Must Do!
Its good stuff.
Old 09-18-2004, 09:57 AM   #8
Oikaze
Junior Member
Re: TRE mod = Must Do!
Quote:
I agree with Strick, I've got an '03 and in addition to the above, the jerks and hesitation that I used to get when closing the throttle in first and second has disappeared.
I don't know if anyone is offering the four-pin connectors found on the SV650 but you can get the three-pin connectors from Jeff Wallace at http://www.jsdproducts.com/Products/...jsd-1_kit.html. I bought two of these kits and used one of them simply to replace the factory connectors- you can just extract the male & female pins from their respective locations and re-install in the new connectors. The only thing different is the plastic housings - no soldering, no fuss, no muss. Then I built the TRE and plugged it in nice & neat. I even used the blind plugs from the four-pin block to plug the 2 blind holes in my new TRE. Secure, water-resistant, professional looking, and easily removeable in case a trip to the dealership is necessary.
The only bad thing is that Jeff doesn't sell his kit with the proper resistor for the SV650, but I picked up a high-quality metal film resistor - 15K Ohm 1/4 Watt 1% Tol. - for 15.
No matter how you accomplish it, this mod is worth your time and trouble.
Oikaze >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Oikaze is offline   Reply With Quote
Old 09-18-2004, 10:26 AM   #9
Marcos Santiago
Member
Bikes: 2002 SV
TRE mod = Must Do!
Guys, do a search for TRE!!!!
I know the search engine in this site is not that great, but I found tons of relevant hits the first time I tried. Here are some (and no, I haven't done that mod):
How to do it...
http://www.svrider.com/tips/retard.htm
http://www.sv650.org/ig_retard/ignition_mod.htm
A different way to do it (weegaz22, the Scottish guy's site)
http://homepage.ntlworld.com/junej.h...gnitretmod.htm
In a 03-04
http://www.sv4me.com/tre.html
Ignition Advance info from Suzuki Canada
http://www.svrider.com/phpbb/viewtopic.php?t=21498
It doesn't make any difference in the dyno?
http://www.svrider.com/phpbb/viewtopic.php?t=14674
Racers' opinion
http://www.svrider.com/phpbb/viewtopic.php?t=17338
Bottom line, IIRC no one has ever posted here two dyno graphs showing a real difference after the mod. But plenty of people has done it and report a very small difference, and mostly no problems.
Whoever wants to do the mod, and have the money for two dyno runs "before and after", please post results.
Marcos
__________________
Click to see my SV650
Marcos Santiago is offline   Reply With Quote
Old 09-18-2004, 10:47 AM   #10
J.J.
Guest
Posts: n/a
TRE mod = Must Do!
Quote:
Marcos
+1
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
