Rear wheel Lock - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 06-29-2013, 12:44 PM   #1
02sv650Sad
Senior Member
Bikes: 02 sv650s 08 vulcan 900 custom
Miles Kms: 38,500
Rear wheel Lock
Hello
this morning, i went for a test ride, and as I was slowing down coming off the freeway, going about 20-25 my Rear wheel locked I had to grab the clutch to prevent a low side. what could cause this? I have not done anything to the bike
other then messing with the carburetor work. and then it did it again 20 feet down again.
02sv650Sad is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-29-2013, 09:08 PM   #2
jreichert
Member
Bikes: 99 sv650, 83 honda ft500
Miles Kms: 34000, 5000
Re: Rear wheel Lock
downshifting too aggressively?
jreichert is offline   Reply With Quote
Old 06-30-2013, 10:40 AM   #3
02sv650Sad
Senior Member
Miles Kms: 38,500
Re: Rear wheel Lock
I was in 2nd or 3rd gear under 2.5K and it locked and rear went to the left. Could it be because I am tuning the carbs?
Old 06-30-2013, 12:56 PM   #4
jreichert
Member
Re: Rear wheel Lock
I wouldn't suspect the carbs sounds like a bind up in the transmission
Old 07-01-2013, 11:44 PM   #5
sdobbs20
Senior Member
sdobbs20's Avatar
Bikes: 03 sv650s.
Miles Kms: 22300
Re: Rear wheel Lock
no not carb related, could be brakes barely dragging enough to build up temp in the system, eventually causing fluid to boil and expand and ultimately lock up.
__________________
MASSIVE GEAR SALE CLICK HERE
sdobbs20 is offline   Reply With Quote
Old 07-02-2013, 08:15 AM   #6
78Chief
Junior Member
Bikes: 2001 SV650/s
Miles Kms: 13000
Re: Rear wheel Lock
were you downshifting while holding the rear brake? the combination of the 2 could have put enough stress on it to lock it up. its happened to me..
78Chief is offline   Reply With Quote
Old 07-02-2013, 09:42 AM   #7
02sv650Sad
Senior Member
Miles Kms: 38,500
Re: Rear wheel Lock
oh yah I think i was on the rear brake little bit while downshifting
Old 07-02-2013, 10:27 AM   #8
O.C. SV650S
Senior Member
O.C. SV650S's Avatar
Bikes: 05 Suzuki SV650S
Miles Kms: 26,000 (10,300 on current)
Re: Rear wheel Lock
I have the same nasty habit, I hold The rear brake while down shifting. I've locked the rear tire a couple of times but thankfully have had my hand on the clutch and pulled in quick enough to stop the tire before it slides 5 inches.
I've always ridden with no back brake, just a habit I built up, now I'm trying to break that habit and sometimes I forgot to release it while down shifting.
Easy to do, don't worry too much, just remember, the minute that clutch comes in to down shift, your foot should come off the rear brake.
O.C. SV650S is offline   Reply With Quote
Old 07-02-2013, 06:23 PM   #9
SU-ZU-KI-V
Senior Member
SU-ZU-KI-V's Avatar
Bikes: 2002 sv650s
Miles Kms: 56000kms
Re: Rear wheel Lock
Are you giving a shot of gas to down shift...dont know your riding history...but a common problem with newer riders to be more on the rear brake than what is needed. On a turn...down shifting very little rear brake. Couple that with no reving a bit...recipe for trouble.
SU-ZU-KI-V is offline   Reply With Quote
Old 07-04-2013, 10:41 AM   #10
NTJordan
Senior Member
NTJordan's Avatar
Bikes: 2001 SV650N, 2009 Kawasaki Versys
Miles Kms: Dunno
Re: Rear wheel Lock
That doesn't really sound like the rear tire chirp you might get from down shifting to me. You mean it locked and stayed locked for more than a split second? Was it free rolling again right after you pulled the clutch?
And for the record, getting the clutch in might not be the way to go. I learned, once the rear is locked, keep it locked and ride the front till you stop. Done it twice now when I got a little to heavy on the rear brake. If you let the rear gain traction again, it might not be pointing the same way as the front which causes the bike to do a nasty little "snap" as it realigns and can cause you to basically pop off the top.
NTJordan is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
