Carb clean - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV650 Gen1 (99-02) Tech
SV650 Gen1 (99-02) Tech Info, advice or questions specific to the 1999-2002 model SV650.
Reply
Thread Tools Display Modes
Old 12-13-2012, 09:24 AM   #1
roadrunnerdavid
Member
roadrunnerdavid's Avatar
Bikes: 2000 Suzuki SV650
Miles Kms: 4700
Carb clean
Does anyone know of a step by step tutorial on how to clean out the carbs on an '00 SV650? I've looked around and found one, but all the photos where gone so it was pretty useless. A video would work as well...I've never done it before and would love to get it done quickly with minimal hassle. Thanks!
__________________
RoadRUNNER Motorcycle Touring & Travel
http://www.roadrunner.travel
roadrunnerdavid is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-13-2012, 09:34 AM   #2
RMAN
Senior Member
Bikes: '05 Triumph Thruxton 900 SOLD, Triumph T595 Daytona, '01 SVS SOLD
Miles Kms: 15,600 15,500 22,000
Re: Carb clean
Do you have a service manual? The manual shows you how to remove and disassemble the carbs. Go to YouTube, doesn't matter if the carbs are not from a SV. Just look for CV carb cleaning.
Here's one link. Go from there, many to view.
You do not need to separate the carbs to clean. Same procedure, just leave the carbs attached, otherwise you will have to synch the carbs once installed, which actually is not a bad idea anyway, but leave the carbs as a pair.
RMAN is offline   Reply With Quote
Old 12-13-2012, 10:24 AM   #3
Cheshyrkat
Member
Bikes: Mine:'08 Buell 1125r & '00 SV650 Frank'nbike; Hers:'02 SV650N
Miles Kms: '08 4.5k; '00 30+K; '02 20+K
Re: Carb clean
Just a tip as it was easier for me. Disconnect the choke cable from the handle and just leave it connected to the carb. It was much easier for me to feed that cable through the frame then to try and remove and reconnect on the carb. I would also replace the bolts on the boot clamps under the carbs to something like a hex cap or allen bolt. Actually while you are at it, you should also replace the screws on the carbs as well. I dont remember the size but replacing them with allen screws makes future work much easier.
Cheshyrkat is offline   Reply With Quote
Old 12-13-2012, 10:53 AM   #4
The Snowman
Member
The Snowman's Avatar
Bikes: Track|Race: 1999 SV650
Re: Carb clean
Disassemble and take photos. That way, you can reference how parts are installed.
It's best to disassemble the carbs one at a time and at a bench and on top of a white rag, since there are quite a few small parts that can go missing if dropped.
__________________
CCS/LRRS Expert#39, retired | Tony's Track Days, Instructor #11 | ECK Racing
The Snowman is offline   Reply With Quote
Old 12-13-2012, 10:54 AM   #5
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Miles Kms: 33k miles
Re: Carb clean
+1 on you tube step by step videos.
It's really not that hard of a process just take your time and do them one by one. That way if you do somehow screw up or get confused you can take apart the other carb and see where you went wrong.
You'll need
Some sort of gloves (carb cleaner dries out hands hella easy)
Carb cleaner
Air compressor (not needed but nice to have for blowing out parts)
Smallest e string from a guitar
Well lit area
Cut in half plastic water bottle to soak the carb parts in
And then all the tools needed to take everything apart
JVS1000S is offline   Reply With Quote
Old 12-13-2012, 02:43 PM   #6
JMod45
Senior Member
JMod45's Avatar
Bikes: 2011 Ninja 1K, 2006 SV650S, 2000 SV650N
Re: Carb clean
You'll need
Carb cleaner
Well lit area
and rags or plastic bags for all the hidden gasoline that will spill out.
JMod45 is offline   Reply With Quote
Old 12-13-2012, 04:15 PM   #7
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Re: Carb clean
Quote:
That too. Lol
Op if you really want some help post up your location and if your anywhere near civilization I'm sure you could find someone to help for a few beers or something
Old 12-14-2012, 08:49 AM   #8
roadrunnerdavid
Member
Miles Kms: 4700
Re: Carb clean
That too. Lol
Good idea, always worth a shot, I do have beer! Anyone near Winston-Salem, NC?
__________________
Old 12-14-2012, 09:10 AM   #9
yev
Member
yev's Avatar
Bikes: 1st Gen Sv650
Re: Carb clean
Quote:
I just had a carb night at my house on Wed. A few buddies came over and walked me through the process while eating some delish Sicilian pizza and drinking some adult beverages.
The easy parts were taking the carbs out and cleaning (rejetting) them. The most difficult part was reassembly for me.
Here is a tip:
Take pictures of everything/anything you can.
If you want to get silly (like I did) take some painters tape and number the tubes for easy reassembly.
Also, lube up your throttle cables while you're there.
Godspeed, good sir!
yev is offline   Reply With Quote
Old 12-14-2012, 09:21 AM   #10
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Re: Carb clean
Your best bet would be to post in the regional section for help.
I'd totally come help for a few brews but I kinda live halfway across the country
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
