question for anyone who has changed out their fork springs... - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > 99-02 SV650 tech
Register Forums Garage FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read Motorcycle EscrowInsurance
99-02 SV650 tech Info, advice or questions specific to the 99-02 model SV650.
Reply
Thread Tools Display Modes
Old 07-02-2012, 06:33 PM   #1
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
Exclamation question for anyone who has changed out their fork springs...
i bought the racetech springs and and off brand emulator and took them into the shop to get worked on. when they pulled everything apart they showed me 2 little springs ( about the diameter of my bike finger and maybe 2 inchs long) that had gotten smashed up. they were sitting on top of a piece of white plastic and looked like they were suppose to sit inside of it and on top of the part #18 here http://www.bikebandit.com/2001-suzuk...7719#sch270475 i think the plastic part was # 8. i didnt have time to order them right then and their so i just did a quick fix job on the spring stuck it back inside the white thing and set it on top of the small end of #18. so i went and ordered part #14 because it was the only other spring on the diagram and seemed to sit in the exact location of the one i pulled out. but the spring that arrived was WAY bigger than the other one that was in there. so now after all that to my question, anyone who has actually pulled their forks apart and seen this piece did the previous owner besides putting it in the wrong space ( on top of #8 instead of in between #8 and #1 use the wrong spring as well or did i some how get the wrong part?
DrPsyc is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-02-2012, 06:49 PM   #2
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
Re: question for anyone who has changed out their fork springs...
there they are, the ones we pulled out were about as long, but half the diameter and the wire was no where near as think as this stuff...
Old 07-03-2012, 09:31 AM   #3
Z32650S
Senior Member
Bikes: 2000 650S, 2002 650S
To me, these look like top out springs. Usually found just under the top lip of the damper rod. See location on rods below.
#8 is a cone looking piece aka "bottom out cone". Some folks remove them when changing their stock damper rods with Traxxion rods. You can see it among the parts at the top right next to the golden looking screw in the pic. Be sure to get a shop manual and reinstall everything in the right order.
While you're in there, I would investigate a bit to find out why the original top out springs you found were mangled, or if they damaged anything else. Just to be safe.
__________________
Ode to SVRider - Build Thread - Discussion Thread
Z32650S is online now   Reply With Quote
Old 07-03-2012, 10:39 AM   #4
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
is yours a 1st or 2nd gen? when the mechanic pulled mine apart the white piece of plastic (maybe a bottom out cone) was sitting on the small tapered end of what in your pic looks like pig nails with the springs i have posted above wrapped around them. and the spring on the OTHER side of all of that. it looked like someone had taken them apart and when they put them back together got the order of those 2 switched up i re wound it and put it in between the 2 as it looked like it belonged. with a spring that big it would just slide down that rod as your is doing instead of sitting on the small tapered end and keeping the plastic off of it as i think it is suppose to do...
Old 07-03-2012, 11:15 AM   #5
Z32650S
Senior Member
I have Gen 1 SV. Pic is not of my forks, just using it to show the various parts.
The top out springs (as shown in your pic) are in place around the rod to prevent your suspension from hitting hard against itself when the forks top out (if they were lifted during a wheelie or sudden dip in the pavement). They may move during operation. Here is how they are placed and how it all works together.
__________________
Old 07-03-2012, 05:42 PM   #6
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
ok so i opened up my haynes and found it page 6-13 figure 8.18b the spring that was inside there was put OUTSIDE on the top and smashed, i re worked it a lil but i want a new one will i have to order the whole "damper rod seat" ?
edit also BB has it as a "piece, oil lock" with 2 different things at 2 different prices, am i going to have to order the whole thing new just for the spring inside?!
Old 07-03-2012, 06:17 PM   #7
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
ok new question since i did the emulator install and drilled out my dampening rod are these even necessary?
Old 07-03-2012, 07:41 PM   #8
RichDesmond
RichDesmond's Avatar
Bikes: Ducati 848, GS1000S, SV650, 650 V-Strom, DR-Z400S, RZ350
Quote:
Yes, you need the top out springs. They need to be in position shown in that photo, below the lip of the damper rod. I've got a set of second gen top out springs, PM your address if you want them.
__________________
Rich Desmond http://www.sonicsprings.com
RichDesmond is offline   Reply With Quote
Old 07-03-2012, 07:44 PM   #9
daviddowns2000
Supporting Member
daviddowns2000's Avatar
Bikes: '02 and '05 SV650N, '05 FJR 1300
Oil lock pieces not needed.
daviddowns2000 is offline   Reply With Quote
Old 07-03-2012, 11:15 PM   #10
DrPsyc
Site Supporter
DrPsyc's Avatar
Bikes: suzuki sv650
Miles Kms: 29000
Garage
Quote:
its not the top out springs im looking for, thats what i accidently bought. what i need is the spring that goes inside the "damper rod seat" as called by haynes or the "piece, oil lock" as called by bike bandit. i called the gurus at racetech and he told me that it helps slow the rod down when its about to bottom out and its not 100% necessary but if/when i bottom out it will be more harsh...
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©1999-2009 SVRIDER.com.
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
