Loss of accel at highway speeds - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > 99-02 SV650 tech
Register Forums Garage FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read Motorcycle EscrowInsurance
99-02 SV650 tech Info, advice or questions specific to the 99-02 model SV650.
Reply
Thread Tools Display Modes
Old 05-11-2012, 12:49 PM   #1
smoothclutch
Member
Bikes: 2001 Red Suzuki sv650S
Miles Kms: 18000
Usually when cruising at highway speed I would feel the bike losing power. The rpms stay steady though. It picks up again when I open the throttle. There were a few instances when I accelerated to pass, the bike seem to "sputter" and eventually respond (after giving her a nasty look or stroking the tank gently while whispering sweet nothings).
The problem was intermittent but now the problem seems to become more common. What are the likely causes of this?
__________________
thou art that
smoothclutch is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-11-2012, 04:48 PM   #2
jd4x426
Member
jd4x426's Avatar
Bikes: 78 xs 500,01 sv650s
Miles Kms: 23,000 miles
Re: Loss of accel at highway speeds
anything done to the bike and have you ever cleaned the carbs
jd4x426 is offline   Reply With Quote
Old 05-11-2012, 06:42 PM   #3
RMAN
Supporting Member
Bikes: Triumph T595 Daytona, '01 SVS SOLD
Miles Kms: 7,660 & 22,000
Spark plugs, dirty air filter, iffy coil, wire lead, cap and even a CDI ignitor box showing signs of saying good bye.
RMAN is offline   Reply With Quote
Old 05-11-2012, 06:46 PM   #4
RandyO
Site Supporter
RandyO's Avatar
Bikes: nekid red 99-135k 07VeeStrom1k- 59k
also check the sound deadening foam on the underside of the fuel tank, if you can pull it away at all, the airbox inlet is getting restricted when the vacuum is enuf to pull it away from the tank
__________________
RandyO
IBA#9560
A man with a gun is a citizen A man without a gun is a subject
RandyO is offline   Reply With Quote
Old 05-12-2012, 08:26 PM   #5
teamcubco
Senior Member
teamcubco's Avatar
Bikes: "99" SV650; "01" SV650; "05" SV650; "02" Speed Triple; "95" SECA" "87" RD250
Miles Kms: 15,000+; 35,000+; 5,780; Who knows
Send a message via AIM to teamcubco Send a message via Skype™ to teamcubco
Try some Sea Foam if all others sys check out. Drain tank completely make sure no H2O, fuel filter clog will do those nasty kinds of things.
__________________
Someday... I'm going to drift on tar like I do on dirt
teamcubco is offline   Reply With Quote
Old 05-19-2012, 07:48 PM   #6
smoothclutch
Member
Miles Kms: 18000
Quote:
I synched the carbs and sprayed some carb cleaner directly in the process
__________________
thou art that
Old 05-19-2012, 07:54 PM   #7
smoothclutch
Member
Miles Kms: 18000
Thanks for the tips! I'll go through your list and see what I find.
__________________
thou art that
Old 05-21-2012, 06:20 AM   #8
smoothclutch
Member
Miles Kms: 18000
Quote:
Bingo! There was actually a hole in the foam from constantly being sucked in the air intake. That was a quick fix to a pretty scary problem. Thanks RandyO!
__________________
thou art that
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
©1999-2009 SVRIDER.com.
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
