RAM mount on my SV - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > Sport Touring / Trips
Sport Touring / Trips Well you asked for it. Post all of your sport touring and trips information, questions and stories in this area.
Reply
Thread Tools Display Modes
Old 04-08-2012, 11:47 AM   #1
motormike645
Member
Bikes: SV
RAM mount on my SV
So I'm planning on taking a trip down from DFW to the Twisted Sisters in Austin Hill Country next weekend and decided it would be good to have a GPS/phone mount on my SV. Here is what I bought from Amazon - the unit is a bit bulky but it certainly holds the phone in place solidly.
Amazon Amazon
I have convertibars on my SV and so I had no space on the handlebars themselves to attach the mount. However, just when I was about to give up, I found the perfect mounting point; there are two vertical bars on either side of the ignition column. Here are some pictures if anyone is considering purchasing a mount like this and is wondering where to put it!
motormike645 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-08-2012, 02:57 PM   #2
forrestlaw
Member
forrestlaw's Avatar
Bikes: 2007 SV 650s
Miles Kms: 6000
Re: RAM mount on my SV
I wouldn't have thought to mount mine like that. I have an 07s and used the 1/4 inch or so of empty space on my clutch side clip-on to mount mine. I will admit I really like having gps on my bike.
What app do you use for your gps?
Also, did you mount a power outlet? If so, where?
__________________
2007 SV650s (Red)
forrestlaw is offline   Reply With Quote
Old 04-08-2012, 03:48 PM   #3
motormike645
Member
Bikes: SV
I use Google Maps on my Android device. Much more accurate than dedicated GPS units I've used in the past like Garmin and Tom Tom in my experience.
I do have a power outlet and you can see it at the bottom of the first picture above - I just mounted it to the front fairing frame with a 3M command strip and a zip tie. Let me know if you would like to see a more detailed picture.
My only concern regarding the GPS is what happens when it starts raining. I guess just pull over and put the phone away...
Old 04-08-2012, 04:12 PM   #4
RMAN
Senior Member
Bikes: '05 Triumph Thruxton 900 SOLD, Triumph T595 Daytona, '01 SVS SOLD
Miles Kms: 15,600 15,500 22,000
You might want to check for waterproof cases at Aerostitch RiderWearhouse.
RMAN is offline   Reply With Quote
Old 04-08-2012, 04:20 PM   #5
Jello Pudding Snacks
Senior Member
Jello Pudding Snacks's Avatar
Bikes: 2009 Suzuki SV650SA
Miles Kms: Eleventy-six
I'll admit judging by the title, I thought you mounted a RAM air intake onto your bike
Jello Pudding Snacks is offline   Reply With Quote
Old 04-08-2012, 04:26 PM   #6
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Miles Kms: 33k miles
I'm not a big fan of the phone mounts built like this. The plastic directly connected to the phone will vibrate and potentially give you some troubles down the road (pun intended). If I was you I'd keep the ram mount (nothing but good things to say about these) and sell the mount and get something else.
Like rman said, waterproof is the way to go. Uglier? Yes but it's functional.
My two pennies.
JVS1000S is offline   Reply With Quote
Old 04-08-2012, 09:22 PM   #7
motormike645
Member
Bikes: SV
My two pennies.
Not sure what you mean... are you saying keep the mount that's on the bike and the arm, but sell the mount that holds the phone? Will the vibration cause damage to the phone over time? If that's a possibility, I'll line the plastic with some shock absorbing material. I would do a waterproof case, but the annoyance then is not being able to use the touchscreen while its covered...
Old 04-08-2012, 09:47 PM   #8
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Sorry bad wording on my part. Yeah the vibrations over time have caused problems for quite a few people who have used this sort of set up. (I was originally saying I think you should keep the mount, ball and arm and sell the actual phone holder and get something else).
A lot of people with car gps's too have reported the same problems with these types of mounts. A vibration resistant material would definitely be a good idea though
Here's what I got for my sv. http://www.ram-mount.com/Products/Aq...5/Default.aspx
Use it for my gps and my iPhone and works great
Old 04-08-2012, 11:19 PM   #9
motormike645
Member
Bikes: SV
That's pretty cool. I'm guessing the touchscreen doesn't work though the cover? Also, can the charger cable or headphone cable be hooked up while the Aquabox is on the device?
Old 04-08-2012, 11:42 PM   #10
JVS1000S
Senior Member
JVS1000S's Avatar
Bikes: 2003 Sv650n
Touch screen works on the gps and the iPhone but the iPhone won't work if I have gloves on (because of the heat sensing touch screen that iPhones have).
I have the cables all routed through the bottom (there's an insert that you drill out).
It's a cool little mount, does look a little bulky and can be a little hard to see in the sun at times but I use it just about every time I go out
Some of the best money I have spent to date (cost about 60 bucks)
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
