SV650 ECM Serial Data Stream Hack - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 03-14-2012, 05:02 PM   #1
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Here is a video of the prototype:
This hack will come in handy if you want to mount, say, an SV650 gen2 gauge on a gen1 bike. Without the data stream from the ECM, the gen2 gauge will be stuck displaying "CHEC", and no way to show engine coolant temperate. Documented here is a way to fix that.
Other potential use for the circuit is to make dual use of the temp readout. Bike voltage could be displayed, or Distance Till Empty (only down to 68 miles as that is the lowest display value) if connected to a fuel gauge (in the works ).
This mod works on the SV650, and may work on other Suzuki gauges, like the GSXR, but I have not tested those.
Step 1 to make this work was deciphering the data stream from the ECM. Using a logic analyzer it was determined that the ECM transmits an 8 byte message once every 100mS (ten times a second). The 8 byte message consist of 7 data bytes, followed by 1 check byte. Bytes are transmitted 10mS apart, with a 30mS gap between message repeat.
See the PIC source code below for the data format.
The challenging part of making this work was figuring out the code for the check byte at the end of the data stream. It's typical to use a CRC (Cyclical Redundant Check; there is a good description on Wikipedia if you're interested). I tested all the common 8 bit CRCs but none matched. Am I doing it right? Are the bytes reversed? Is the bit order correct...?
Without the proper code byte at the end of the data stream it's impossible to make "CHEC" go way. Having the proper data is not enough. The code byte at the end must match too.
I was about to give up, defeated, when it dawned on me that the check byte might not be a CRC at all. A simpler method is to use CheckSum (check the easy things first, right?!). CRC performs division, CheckSum is simple addition. After a few checks, turns out it was CheckSum not CRC! Haha, I was thrilled!
In hindsight it makes sense that the check byte was not CRC. CRC is quick calculation in hardware, but without a dedicated circuit (SV's ECM probably doesn't have one) it takes many cycles in software. A software checksum is a faster to perform than a CRC and would leave precious processing time for the ECM to perform other functions. Checksum it is.
Here is the prototype I'm sending to brle7817 to test with his GSXR gauge. The potentiometer (variable resistor) sticking out the top is for testing and gets removed when the real ECT thermistor is hooked up.
Schematic
MikroElektronika BASIC Source Code
Code:
program SV650_ECM_Serial_Hack
'Date: March 14, 2012
'Part: PIC16F1847
'Design: TeeRiver, at SVRider.com
'Ver:1.0
'Use: SV650 Gen2 ECM Serial Stream Emulator
dim ecm_serial_byte as byte[8] '8 bytes, 0 thru 7
dim check_sum as byte
dim index as byte
dim adc_value as word
const dealer_mode = 0
const temp = 0  '0 thru 1023
const C11 = 0 'Undefined for SV650
const C12_CKP = 0
const C13_IAP = 0
const C14_TPS = 0
const C15_ECTS = 0
const C21_IATS = 0
const C22_CAM = 0 'Not used on SV650
const C23_TOS = 0
const C24_IG_Coil_1 = 0
const C25_IG_Coil_2 = 0
const C28_STVA = 0
const C29_STPS = 0
const C31_GPS = 0
const C32_FI_1 = 0
const C33_FI_2 = 0
const C41_FP_Relay = 0
const C42_IG_Switch = 0
const C43 = 0 'Undefined for SV650
const C44 = 0 'Undefined for SV650
const C49_PAIR = 0
const Adj_TPS_0 = 0
const Adj_TPS_1 = 0
sub procedure Boot_up()
  'Set internal oscillator
  OSCCON = %01110000 '8MHz
  'Set all PIC I/O to DIGITAL, except for ADC1
  ANSELA = %11100010' Configure all 5 PortA AN pins (A4:A0) as DIGITAL I/O
  ANSELB = %00000001' Configure all 7 PortB AN pins (B7:B1) as DIGITAL I/O
  'Set I/O port direction
  TRISB = %11101011 'B4 is test strobe, B2 is UART TX
  TRISA = %11111111
  'Initialize the UART
  UART1_Init(7800)
end sub 'Boot_up
main:
  Boot_up()
  'Initialize ECM Data Stream
  for index = 0 to 7
    ecm_serial_byte[index] = $00
  next index
  'Assign Error Code bits to data stream
  ecm_serial_byte[1].4 = dealer_mode
  ecm_serial_byte[3].0 = C11 'Undefined for SV650
  ecm_serial_byte[3].1 = C12_CKP
  ecm_serial_byte[3].2 = C13_IAP
  ecm_serial_byte[3].3 = C14_TPS
  ecm_serial_byte[3].4 = C15_ECTS
  ecm_serial_byte[3].5 = C21_IATS
  ecm_serial_byte[3].6 = C22_CAM 'Not used on SV650
  ecm_serial_byte[3].7 = C23_TOS
  ecm_serial_byte[2].0 = C24_IG_Coil_1
  ecm_serial_byte[2].1 = C25_IG_Coil_2
  ecm_serial_byte[4].5 = C28_STVA
  ecm_serial_byte[4].6 = C29_STPS
  ecm_serial_byte[2].2 = C31_GPS
  ecm_serial_byte[2].3 = C32_FI_1
  ecm_serial_byte[2].4 = C33_FI_2
  ecm_serial_byte[2].7 = C41_FP_Relay
  ecm_serial_byte[1].0 = C42_IG_Switch
  ecm_serial_byte[1].5 = C43 'Undefined for SV650
  ecm_serial_byte[4].3 = C44 'Undefined for SV650
  ecm_serial_byte[4].7 = C49_PAIR
  ecm_serial_byte[1].1 = Adj_TPS_0
  ecm_serial_byte[1].2 = Adj_TPS_1
  ecm_serial_byte[0] = temp >> 2
  ecm_serial_byte[1].7 = temp.1
  ecm_serial_byte[1].6 = temp.0
  while true
    portb.4 = 1 'Test strobe
   'Read the ECT thermistor
    adc_value = ADC_Read(1)
    'Assign thermisor adc voltage to serial data stream
    ecm_serial_byte[0] = adc_value >> 2
    ecm_serial_byte[1].7 = adc_value.1
    ecm_serial_byte[1].6 = adc_value.0
   'Calculate the checksum.
    check_sum = 0
    for index = 0 to 6
      check_sum = check_sum + ecm_serial_byte[index]
    next index
    'Calculate two's compliment
    check_sum = 256 - check_sum
   'Send the datastream
    for index = 0 to 6
      UART1_Write(ecm_serial_byte[index])
      delay_ms(10)
    next index
    UART1_Write(check_sum)
    'Inter-message gap
    delay_ms(30)
    portb.4 = 0
  wend
End.
Intel Hex File, Programming data for PIC 16F1847, if you'd like to burn a copy of the chip for yourself.
Code:
:02000000E028F6
:0C0006000E30FD00FD0B05280000080076
:1000120048302000B7000030B8004530B900003049
:0E002200BA00F03021009E009D011D14080060
:10003000D6302000A1000030A2004230A3000030E2
:10004000A400FF30B300FF30B4000030B500003032
:10005000B600FF30AF00FF30B0000030B10000301C
:10006000B200FF30BB00FF30BC000030BD000030EC
:10007000BE0023009E1690309D0021008D140D11AE
:100080002000911E472823001908F000402808008E
:10009000833021009D0520004508F000F035F03543
:1000A000700821009D0403209D149D1C5928000008
:1000B00055281C08F100F0011B0870042000C60040
:1000C0007108C7000030C7044608F0004708F10077
:0200D000080026
:1000D2002000F801F9011030FC00710DF80DF90D46
:1000E2007408F8027508031C750FF90203188028BA
:1000F2007408F80775080318750FF9070310F00D57
:08010200F10DFC0B6E28080052
:10010A00092020004208C50048207008C300710871
:10011A00C40021001D1020004308F0004408F1002B
:02012A000800CB
:10012C00703021009900E23023008C0001308D00EA
:10013C00FB3021008D00FF308C0023009F159C01AB
:0C014C00FF309B009C011E1518200800CD
:100158002000FB01FA01F9018030F800F10CF00CE5
:10016800031CBF287408F90775080318750FFA07E8
:100178000318FB0A0310F01FC7287408FA0775084C
:100188000318750FFB07FB0CFA0CF90CF80C031C91
:10019800B2287B08F3007A08F2007908F1007808A1
:0401A800F00008005B
:1001AC0023009E18DB280000D628200042082300DC
:0401BC009A0008009D
:1001C00096202000BF0125308600003087003F08C0
:1001D00086070318870A81013F08073A0319F228A6
:1001E000BF0AE32826122810A8102811A8112812E7
:1001F000A8122813A8132710A710A9122913271132
:10020000A7112712A7132610A612A911A913A61029
:100210002611A501A61326130D160130C200852054
:100220007008AD007108AE006430F400F501AC2038
:100230007008C0007108C1002D08F0002E08F10000
:100240005E30F400F501AC2070084002F000710847
:10025000413BF1006430F400F501692070082D077E
:10026000F30071082E3DF4007308AD007408AE0071
:100270007308F0007408F100F136F00CF136F00C60
:100280007008A500AD184629A6134729A6172D18F2
:100290004B2926134C292617A001BF0125308400C5
:1002A000003085003F0884070318850A0008A0076E
:1002B0003F08063A03195E29BF0A4E292008003C70
:1002C000A000BF0125308400003085003F0884076E
:1002D0000318850A0008C200D6201A30FC00F83046
:1002E000FD00FD0B7129FC0B7129000020003F0867
:1002F000063A03197D29BF0A62292008C200D620C8
:100300004E30FC00EB30FD00FD0B8429FC0B8429F2
:0803100020000D120C298B29BD
:020000040001F9
:04000E00A43F1316E2
:00000001FF
I hope you like it!
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-14-2012, 05:15 PM   #2
ineedanap
Senior Member
ineedanap's Avatar
Bikes: 2007 r6 (track only) 2014 ZX10R (street only) Crashed all my SVs
Miles Kms: eleventy million
Re: SV650 ECM Serial Data Stream Hack
My brain hurts. Nice job.
Quote:
Originally Posted by TeeRiver View Post
Using a logic analyzer it was determined that...
Do they have a model that will work on people too?
ineedanap is online now   Reply With Quote
Old 03-14-2012, 07:15 PM   #3
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
I once hooked it up to my wife and it immediately blew the circuit breaker.
__________________
Old 03-14-2012, 10:18 PM   #4
Rock Dodger
Supporting Member
Rock Dodger's Avatar
Bikes: 2006 Suzuki SV650N
Miles Kms: 50,000+ mi.
Wow, that's impressive. Over my head, but impressive. Awesome work, TeeRiver! A gear position indicator would be child's play for a whiz like you. (Hint, hint.....)
__________________
Check out Soliton's Brake Light Flasher!!
Rock Dodger is offline   Reply With Quote
Old 03-14-2012, 10:41 PM   #5
bighammer
Senior Member
bighammer's Avatar
Bikes: 2004 SV650 Yellow
I don't have that kind of electronics smarts, but I find it fascinating to see what the people who do, can come up with. Nice work.
__________________
Yes, I'm the HammerGrips guy.
bighammer is offline   Reply With Quote
Old 03-14-2012, 10:49 PM   #6
ebrammer252
Senior Member
ebrammer252's Avatar
Bikes: 2000 Naked SV-650
Miles Kms: 34,000
I vote for crafting and selling an adapter setup to hookup a second gen gauge cluster on a first gen!!!
__________________
2000 SV-650 Naked : My Garage
Build Thread -- Comment Thread
Formerly known as that douchebag ebrammer252
ebrammer252 is offline   Reply With Quote
Old 03-15-2012, 12:39 PM   #7
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Thanks guys! I appreciate the kind feedback.
Quote:
Originally Posted by Rock Dodger View Post
... A gear position indicator ... (Hint, hint.....)
Rock, one of these days I will post a thread on how to build this GPI, including all the juicy details (parts list, schematic, code, instructions ...). It's based on the same PIC chip and Radio Shack proto-board as the ECM build above, only different software and has a 7 segment LED attached.
Here is a close up photo. I tried to make the unit as small as possible so it can be mounted inside the SV gauge via a cutout through the tach face. This photo shows the entire unit, no separate power box, connects with just the three wires: Red (12v), Black(gnd), and Green(tap the SV's gear position sensor wire). At the moment, I'm searching for a 7seg LCD display instead of the power hungry LED to get the heat down. With no air circulation it gets a bit hot inside the gauge housing.
__________________
Old 03-15-2012, 02:20 PM   #8
Rock Dodger
Supporting Member
Hey TeeRiver, I watched the video; yours works better than mine.
Mine shows false neutrals and the wrong gear, for a up to second or so, from time to time. I'm not sure what causes it. It's got an big LED display, probably too big, but it's very easy to read. An LCD would need a back light; no problem I'm sure.
About putting it in the speedo housing; that takes the mod from plug and play to a much higher level of difficulty. I would go for an outside mount, myself. Edited to add: combining this with a tre would be a good thing, IMO.
You sure seem to keep busy doing some great stuff!
__________________
Old 03-15-2012, 02:35 PM   #9
BeatnikBrown
Member
BeatnikBrown's Avatar
Bikes: Suzuki 2008 SV650SF (blue)
Send a message via AIM to BeatnikBrown Send a message via Yahoo to BeatnikBrown
eagerly watching the results of all this
BeatnikBrown is offline   Reply With Quote
Old 03-15-2012, 10:53 PM   #10
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
I had the same problems, Rock. There is a lot of noise on the signal from the gear position sensor. This makes it a challenge to accurately recognizing gear changes (and by challenge, I mean a major pain in the ass!). It took some tweaking and software tricks to get quick gear changes and make the false neutrals go away.
Do you remember the Cheap GPI Thread that never came to fruition? I believe they hit the same problems. A design can work beautifully on the bench, but once mounted on the bike, all hell may break loose. The devil is in the details!
Bighammer actually took the SV gear position sensor apart and exposed the individual gear contacts. It would use a few more wires, but a design based on that would be rock solid and fast. I think he should build it.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
