Filtered valve core needed for Dyna beads? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 03-23-2011, 01:07 PM   #1
faber
Site Supporter
faber's Avatar
Bikes: 06 SV1000S, 79 CX500, 82 XS400
Miles Kms: ∞
Hi guys,
I'm going to switch to Dyna beads for my next set of tires. Does anyone know if the filtered valve core is required or recommended on cycle tires?
__________________
Check out my active project bikes at FMBikes.com
faber is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-23-2011, 01:19 PM   #2
sbhockey
Site Supporter
sbhockey's Avatar
Bikes: 01 SV650 track only, 05 CBR600RR street mule
Miles Kms: never enough
Re: Filtered valve core needed for Dyna beads?
I've got ghetto Dyna Beads (air soft pelets, and lots of em) on my winter beater Ford Ranger. No filtered valve stem on there.
__________________
“Riding is and always will be my first priority. Through the distractions and inevitable failures in other parts of my life I know that all I have to do to feel better is ride.”-Ryan Clark
sbhockey is offline   Reply With Quote
Old 03-23-2011, 01:36 PM   #3
Rock Dodger
Supporting Member
Rock Dodger's Avatar
Bikes: 2006 Suzuki SV650N
Miles Kms: 50,000+ mi.
I have used Dyna Beads for two years and haven't used filtered valve cores. But on one occasion a bead got stuck in the valve core and wouldn't come out, so I lost all the air out of the tire. I was at home at the time, so I just put a new core in. Now I carry spare valve cores on the bike and a core tool.
Problem with filtered cores, they don't come in lengths we can use on bikes, IIRC. If I could get some that would work, I would definitely use them.
__________________
Check out Soliton's Brake Light Flasher!!
Rock Dodger is offline   Reply With Quote
Old 03-23-2011, 01:48 PM   #4
Lgn001
Senior Member
Lgn001's Avatar
Bikes: 2000 SV650
Miles Kms: 64K
You don't need the filters, but it is a good idea to put a blast of air through the stem before you check the pressure. It's also a good idea to have the stem positioned between 6 o'clock and 8 o'clock before you check pressure.
If you add them right after you mount a tire, check to make sure there isn't any condensation in the valve stem. The last time I added them, I had just mounted the tire, pressurized it to seat the beads, and let the air out to install the beads. They would NOT go in, no matter what I did. I thought about it for a bit, and sure enough, there was water in the stem from the air escaping. I dried it up with a paper towel, and everything went much smoother.
Lgn001 is offline   Reply With Quote
Old 03-23-2011, 05:40 PM   #5
2Zukis
Senior Member
2Zukis's Avatar
Bikes: '03 SV650 & Bandit 1250
Miles Kms: SV: 11,000 miles - Bandit: 40,000
Dyna Beads.... love 'me. Been using them in the Bandit for tens of thousands of miles and now on the SV. My tires wear better with no obvious cupping or scalloping.... they work.
I never had any problems with them
- but -
I'm gonna try to keep the above in mind, THANKS!
2Zukis is offline   Reply With Quote
Old 03-23-2011, 07:48 PM   #6
jeramoo
Member
jeramoo's Avatar
Bikes: 2005 kaw vulcan 800, 08 sv650n
Miles Kms: 5500
2Zukis do you reuse yours? I am gonna be mounting a new set of tires and I am not sure whether I should try and save the ones in my current tires.
__________________
Sometimes you gotta do things!
my luggage rack
http://forum.svrider.com/showthread.php?t=108471
jeramoo is offline   Reply With Quote
Old 03-23-2011, 08:10 PM   #7
Rock Dodger
Supporting Member
Quote:
I reuse mine. Some of them get covered in rubber, but they still work. I've recycled mine several times. You always end up spilling some when you change tires, but you get at least 85 to 95% back out of the old tire.
__________________
Old 03-23-2011, 08:24 PM   #8
trace33chargers
Senior Member
trace33chargers's Avatar
Bikes: 2000 SV650 Supersport, 2010 Ninja 250R
I know this isn't helpful, but I need to say it. Dyna beads are dumb and I don't approve of their use.
__________________
CCS MW #390
trace33chargers is offline   Reply With Quote
Old 03-23-2011, 08:24 PM   #9
bighammer
Senior Member
bighammer's Avatar
Bikes: 2004 SV650 Yellow
Quote:
I thought I was the only cheapskate around here. I used some #9 birdshot from a gun shop.
Not sure you need a filtered valve stem for any application. Think about it; what are the chances of getting a bead into the stem? Ypu'd have to be letting out air with the valve as the very lowest point. (pretty much impossible to do)
__________________
Yes, I'm the HammerGrips guy.
bighammer is offline   Reply With Quote
Old 03-23-2011, 09:15 PM   #10
jeramoo
Member
jeramoo's Avatar
Miles Kms: 5500
Quote:
is there any logic or reason behind this? please explain.
__________________
my luggage rack
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©1999-2009 SVRIDER.com.
