How to change your spark plugs - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 02-13-2011, 09:39 AM   #1
darkblue52
Member
darkblue52's Avatar
Bikes: 2003 SV650 N
Post How to change your spark plugs
I know the 07+ have 4 plugs right? but 03-06 only have two i think. Can anybody post a tuturial (with pics would be awesome!) on changing the plugs in an 03-06, showing location of plugs and best way to reach them?
__________________
Quote:
Originally Posted by MagpieTear View Post
I thought sharpies were for sniffing, you mean you can draw with them?
Quote:
Originally Posted by selztoad View Post
I guess the govurnmeant edukation I receiv'd is not paying off
darkblue52 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-13-2011, 10:30 AM   #2
champer
Senior Member
Bikes: 2000 SV650s
Re: How to change your spark plugs
Rear plug: Remove seat, unbolt front of gas tank, tip tank upwards (make sure not to have it full of gas or it will leak out the top) and use a rod (one comes in the tool kit) to hold it up. The rear cylinder is right at the base of the tank. Pull the wire + plug out of the top of it, remove the spark plug with a spark plug socket on an extension. I believe there is a spark plug tool in the toolkit as well.
Front spark plug: Remove any necessary bodywork if a S model, unbolt the 3 bolts holding the radiator in place. Push radiator forward, there is the top of the front cylinder. Remove the plug and wire and then remove the spark plug with a spark plug socket. The factory tool does a good job of getting in there, as it is a tight space with the radiator there.
To install new plugs: put a dab of anti-seize on the threads, turn plug in by hand, once it is tight by hand, tighten with a wrench another 1/4 to 1/2 turn. Make sure it is snug but not overly tight, as you can strip the threads.
When putting the plug back on the front spark plug, put some dielectric grease in the plug boot, will help protect against water.
__________________
Buncha SV's...
champer is offline   Reply With Quote
Old 02-13-2011, 10:51 AM   #3
marlonjb007
Site Supporter
marlonjb007's Avatar
Bikes: Track/Street, Suzuki SV-650 2006, 2006 S2R Ducati
Miles Kms: 8,200
Go to bolty.net and look for the link for SV650... they have a full write up with pics. Btw, so the 2006 only has 2 plugs?
marlonjb007 is offline   Reply With Quote
Old 02-13-2011, 11:03 AM   #4
marlonjb007
Site Supporter
Miles Kms: 8,200
Here it is. I never realized that the 07+ are dual spark. It says it at the beginning of the write up!!
Here it is, but remember only the rear and front apply to your case:
http://bolty.net/2009/10/06/how-to-c...in-your-sv650/
Old 02-13-2011, 09:38 PM   #5
darkblue52
Member
darkblue52's Avatar
Bikes: 2003 SV650 N
great! thanks. quite simple once you know.
__________________
Old 02-14-2011, 05:48 AM   #6
marlonjb007
Site Supporter
Miles Kms: 8,200
Quote:
I did mine's yesterday. Actually, just before I started I saw this thread and I said, wait a minute.... It's the 2007 that has the 4..
But yeah, pretty simple. Just hand tight and a half a turn at the end.
Old 02-14-2011, 06:12 PM   #7
Rock Dodger
Supporting Member
Rock Dodger's Avatar
Bikes: 2006 Suzuki SV650N
Miles Kms: 50,000+ mi.
Or better yet, use a torque wrench.
__________________
Check out Soliton's Brake Light Flasher!!
Rock Dodger is offline   Reply With Quote
Old 02-14-2011, 06:37 PM   #8
friendlyfoe
Senior Member
Bikes: 08 SV650
Miles Kms: 10 000km's
Quote:
or better yet, dont. Hand tight and you usually dont even need a full half turn, just a tiny bit tight past snug. No need for a tq wrench on spark plugs.
__________________
Quote:
Originally Posted by bfeils View Post
If it happens again touch the headers and see if one of them is much cooler than the other. Do it very quickly obviously so you don't get burned.
friendlyfoe is offline   Reply With Quote
Old 02-14-2011, 06:48 PM   #9
marlonjb007
Site Supporter
Miles Kms: 8,200
IMO, torque wrenches are pretty good to adjust big bolts and values that are in the middle range. Small values tend to be inaccurate. To improve accuracy, i would use a 1-25 lb.ft(I don't have one for that range) to be able to adjust to 8 lb. ft. Since I am an engineer, I would usually suggest to stick to the spec. But sometimes, you have to follow common practice. Half a turn works.
Old 11-16-2014, 06:48 PM   #10
DrRoebuck
Junior Member
Bikes: SV650S
It seems bolty.net is no more, as I haven't been able to access that site for about a week. Is there a tutorial anywhere for changing the spark plugs on a 2010 SV?
DrRoebuck is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
