Valve clearance check experiences - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
Register Forums Garage FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read Motorcycle EscrowInsurance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 12-08-2010, 04:33 PM   #1
derj
Member
Bikes: '03 SV650N
Miles Kms: growing daily
Last year I checked my valve clearances......bike had 12,000 miles....and I found 1 exhaust valve to be at a very tight minimum clearance and the other 7 to be comfortably at minimum clearance. Not uncommon findings. I decided to just adjust the one exhaust valve and check the rest again at 18,000....just in case. Well, that 18,000 mile mark happened sometime in September and I was too busy riding, so I kept putting it off. Besides, reshimming is a PITA. Today, at 21,000 miles, I checked the clearances again. I was happy to find that all of them stayed just about where I left them at 12,000 miles. I found out for my skeptical self what has been mentioned here many times......If the valves are within spec....even right at the minimum.... leave them be. They really do hold their adjustment quite well.
derj is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-08-2010, 04:37 PM   #2
scott26
Senior Member
scott26's Avatar
Bikes: 2005 Suzuki SV1000S
Miles Kms: 19,000 Miles (and growing)
Re: Valve clearance check experiences
I had check mine at 15,000 to find them in spec... but was uneasy about the quality of work I did the first time so I did it again a 20,000 taking the radiator out and all and found them to still be within spec... saved me $300 at a shop.
__________________
K5 SV1000S BLK: GSXR 1000 Rear Shock, Racetech Springs, Nuc Custom Sliders, Desnorkeled, DIY Drilled Exhaust, DIY TRE, Stickers (For Aerodynamics). DIY Luggage Rack
scott26 is offline   Reply With Quote
Old 12-08-2010, 05:06 PM   #3
rcannon409
Supporting Member
Bikes: 2003 sv 650s 2008 Concours 14abs
Miles Kms: 14,000
Guys, was this a difficult job? I am getting ready to check mine on an 03 with 15k. Any tips not listed in the manual?
rcannon409 is offline   Reply With Quote
Old 12-08-2010, 09:46 PM   #4
derj
Member
Bikes: '03 SV650N
The checking of clearances is not a difficult job. Removal of the radiator will make things a bit more roomy when dealing with the front cylinder but I don't think that its removal is required for just checking clearances. It probably would be worth doing if you have to reshim the front but just unbolting it and moving it out of the way (be careful with the fins BTW) would be enough to just check clearances. As in all things..... YMMV.
Old 12-08-2010, 10:10 PM   #5
bcj
Senior Member
bcj's Avatar
Bikes: k3 sv650
I bought my k3 with 11k miles and put off the checkup until 20k. Was having too much fun.
Only two exhaust shims were slightly tight. Everything else was comfortably within spec.
New chain and sprockets at the same whirlwind cleanup session.
I'm very happy with the mechanicals in my SV.
bcj is offline   Reply With Quote
Old 12-09-2010, 09:15 AM   #6
champer
Senior Member
Bikes: 2000 SV650s
Quote:
It's not overly difficult. If you have a service manual and a solid afternoon you should be able to do it.
The annoying part comes if the plug on the left side case cover does not come out (and then you strip it). You need to take this plug out to turn the engine over by hand.
I suggest using an impact if you can get one. I've had 2 strip out of 4 engines. When reinstalling - make sure to put some antiseize on the threads and o-ring. Doing this when I try to take them out again they come out easy.
__________________
Buncha SV's...
champer is offline   Reply With Quote
Old 12-09-2010, 09:23 AM   #7
scott26
Senior Member
scott26's Avatar
It is not that hard of a job you just have to pay attention to detail. It is not needed to remove the radiator but if you dont plan to get cut up some and curse a lot more. As far as the impact goes I think you are talking about the generator plug if so dont use an impact on that. I think it is an alumminum plug which will not go well with the power of an impact... just use a wrech... and if worst case senario use a breaker bar no impacts though.
__________________
Old 12-09-2010, 12:26 PM   #8
champer
Senior Member
Bikes: 2000 SV650s
Quote:
Yes that plug.
I've had better luck with the impacts - using a breaker bar for me has resulted in stripping out Allen hole in the plug making it circular.
__________________
Buncha SV's...
Old 12-09-2010, 12:58 PM   #9
scott26
Senior Member
scott26's Avatar
Well to each there own.
__________________
Old 12-09-2010, 01:37 PM   #10
Lgn001
Senior Member
Lgn001's Avatar
Bikes: '83 CB1100F, '00 SV650, ex-'07 VFR
Rather than remove the plug, put it in second gear and "bump" the bike forward.
Lgn001 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©1999-2009 SVRIDER.com.
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
