tip over sensor - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 12-20-2009, 08:31 PM   #1
nater
Junior Member
Bikes: 07 SV650S, 06 GSXR750, 04 KTM 200EXC
Miles Kms: 3000
tip over sensor
How does one reset a tip over sensor? Engine code is saying c23 which is the TOS. Bike is an 07 SV650.
nater is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-20-2009, 09:14 PM   #2
Davinci
Senior Member
Davinci's Avatar
Bikes: 09 DRZ 400SM
Miles Kms: 15,200
Send a message via Yahoo to Davinci
Re: tip over sensor
Verify that it is installed in the upright position.
From the Manual:
TO SENSOR INSPECTION
TO SENSOR REMOVAL AND INSTALLATION
The tip over sensor is located in front of the battery . (r-74-35)
Remove the right frame cover . (r P7-4)
Remove the TO sensor from the battery case .
Install the TO sensor in the reverse order of removal .
NOTE:
When installing the TO sensor, the arrow mark OA must be
pointed upward.
__________________
Quote:
Originally Posted by SnootyBikeMike View Post
the only interaction I'll have with babies is when I'm puting them into and taking them out of boxes.
Davinci is offline   Reply With Quote
Old 12-21-2009, 09:24 AM   #3
nater
Junior Member
Miles Kms: 3000
Re: tip over sensor
It is in the upright position. The arrow points up.
The bike was tipped over. If I shake the TOS, something rattles inside.
Old 12-21-2009, 10:05 AM   #4
Verbal Kint
Senior Member
Verbal Kint's Avatar
Bikes: Cram it.
Re: tip over sensor
If the code says tip over sensor, and the TOS is installed properly......
Pick up the bike.....
...or...
Your sensor may be dead. Replace it.
Do you have any other SVRiders in your neighborhood, that you could borrow one, to verify that it's bad?
Verbal Kint is offline   Reply With Quote
Old 12-21-2009, 10:10 AM   #5
nater
Junior Member
Miles Kms: 3000
Re: tip over sensor
...or...
No other SV owners that I know, but that is a thought.
I was thinking that I might need a new sensor. I was thinking of turning it upside down just to see if the previous owner had messed with it and put it back on wrong...
Old 12-21-2009, 10:36 AM   #6
nitsuJ
Member
nitsuJ's Avatar
Bikes: 2007 SV650S
Miles Kms: 4500
Re: tip over sensor
This may be a stupid question... but do all SV's have a tip over sensor? And if so, what does it do besides sensing a tip over? I've had my bike run into twice and nothing happened or no code came up.. is it something that you install aftermarket? Should something have happened to my bike when it was ob its side? Just curious, as i bought my bike used
nitsuJ is offline   Reply With Quote
Old 12-21-2009, 11:28 AM   #7
superwormy
Senior Member
Bikes: 2003 SV650 (street), 2005 SV650S (LRRS #358)
Miles Kms: 25,000+ miles
Send a message via AIM to superwormy
Re: tip over sensor
The TOS kills the engine when the bike is on it's side. If the bike is upright, the TOS isn't active and the bike runs fine.
Did you bike shut itself off when you tipped it over? If so, then your tip over sensor works fine.
__________________
- Keith Palmer
CCS/LRRS Novice #358
2007 Daytona 675 (street) - 2003 SV650n (street) - 2005 SV650S (race)
superwormy is offline   Reply With Quote
Old 12-21-2009, 12:17 PM   #8
bcj
Senior Member
bcj's Avatar
Bikes: k3 sv650
Re: tip over sensor
Could be a loose plug or corroded connector somewhere in the wiring loom.
The error code means the ECU is not getting the the right (or any?) reading from that bit of hardware.
The sensor resets itself when you pick the bike upright. The little rattly bit is what falls off the contacts when it is on it's side.
bcj is offline   Reply With Quote
Old 11-29-2012, 01:36 PM   #9
Exhausted
Senior Member
Exhausted's Avatar
Bikes: Suzuki - SV650N - 2008
Miles Kms: 24800mi
Question Re: tip over sensor
Sorry to necro this, but i was just thinking, i have never actually seen my tip sensor (been under the seat numeros times) and i've also tipped the bike over a few times and cant quite remember if the engine shut itself off or if i hit the kill switch.
But more important to me, when I got the bike back upright i went to turn the bike on (no error code) and it wouldnt start...then a few minutes later it did start up just fine (i assumed the tip sensor needed to reset itself) is this the way it should work or should an error get thrown as suggested above? (and you'd need to remove/re-orientate the sensor?)
__________________
Shift-positive
Exhausted is offline   Reply With Quote
Old 11-29-2012, 03:59 PM   #10
onecartel
Senior Member
onecartel's Avatar
Bikes: YJ50, CB500X, GSXR600
Re: tip over sensor
One time I was negligent with reassembly and mounted mine funny. This resulted in the bike cutting out on hard launches-- the symptoms were similar to yours, the bike would cut and wouldn't start immediately afterwards. Typically just flipping the ignition on/off would clear it up.
AFAIK, c23 is triggered when there is an issue with the TOS and not under 'normal' operation.
onecartel is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
