Fuel Injectors - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Reply
Thread Tools Display Modes
Old 12-19-2009, 12:21 PM   #1
DriftinSideways
Junior Member
DriftinSideways's Avatar
Bikes: 2004 SV650N
Miles Kms: 6000
Fuel Injectors
My SV sat dorment for quite some time. I tried starting it the other day she will run off either but the injectors seem to be clogged. Could you guys help me with trying to find a way to clean them?
Travis
DriftinSideways is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-19-2009, 02:07 PM   #2
BuilderBob
Senior Member
BuilderBob's Avatar
Bikes: 2012 K1600GT, 2008 KLR 650, 2008 WR250X
Miles Kms: who cares?
Re: Fuel Injectors
There are plenty of fuel injector cleaner fuel additives that you can buy at your local auto parts store. Wal-Mart probably has them as well. Buy some and follow the directions.
__________________
Bob's Blog
BuilderBob is offline   Reply With Quote
Old 12-19-2009, 03:15 PM   #3
DriftinSideways
Junior Member
Bikes: 2004 SV650N
Miles Kms: 6000
Re: Fuel Injectors
Yeah I did try that and no luck is there a better way or should I buy new injectors
Old 12-19-2009, 03:28 PM   #4
VARIABLE9
Platinum Member
VARIABLE9's Avatar
Bikes: 2006 SV650 K6
Re: Fuel Injectors
Quote:
Travis
How long did it sit for?
Indoors or out?
What else have you done to troubleshoot?
Seems odd to me that a 2004 would already be clogged up unless it sat since 2005.
__________________
Coolest blog on the planet = WhiskeyRacer.tumblr.com
Second coolest blog on the planet = WhiskeyRacer
VARIABLE9 is offline   Reply With Quote
Old 12-19-2009, 03:48 PM   #5
DriftinSideways
Junior Member
Bikes: 2004 SV650N
Miles Kms: 6000
Re: Fuel Injectors
I wrecked it in 05 and sold it I bought it back 6 months ago I ago the guy said it ran but who knows. Ive tried blowing air through it and let it sit in a bowl of injector cleaner. Im prett sure its the injectores I can hear the fuel pump turn on with the key and the fuel lines are not clogged.
Old 12-19-2009, 03:53 PM   #6
markyboy650sf
Member
markyboy650sf's Avatar
Bikes: 2008sv650s
Miles Kms: 34500m
Re: Fuel Injectors
old gas has varnished up the fuel system i suspect
__________________
m4 slip on...zx10r shock...ricor front...dual radius w/s...seat cowl...pilot powers
markyboy650sf is offline   Reply With Quote
Old 12-19-2009, 04:04 PM   #7
Fizzled
Member
Bikes: 2007 Yamaha FZ1
Miles Kms: 30000
Re: Fuel Injectors
If you're confident that the injectors are at fault and have ruled out all other possibilities I would just send your injectors for a proper flow-rate test and have them call you prior to performing any cleaning/matching services.
Alternatively if you can find a cheap set of Throttle Bodies and/or injectors you can try that too... however just be wary that you might bring yourself right back to the same problem of needing to have a professional cleaning done.
Simply soaking injectors doesn't do much.
Fizzled is offline   Reply With Quote
Old 12-19-2009, 04:39 PM   #8
VARIABLE9
Platinum Member
VARIABLE9's Avatar
Re: Fuel Injectors
Oh, maybe more reasonable then.
__________________
Old 12-19-2009, 05:15 PM   #9
DriftinSideways
Junior Member
Bikes: 2004 SV650N
Miles Kms: 6000
Re: Fuel Injectors
Thanks guys Ill send them off when I go home on leave thanks.
Travis
Old 12-20-2009, 11:55 PM   #10
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Re: Fuel Injectors
Hi Travis,
Please let us know how that works out for you. We don't see too many cases of clogged injectors on the SV. I'd be interested in knowing if that fixes your problem, how successful cleaning them is, or if replacement is required since the bike sat for so long, (>3years?).
I'm actually surprised your fuel pump still makes operating sounds. You might want to test fuel pump pressure and flow rate. Pressure should be about 43psi, and flow should be 168ml/10sec. It's probably a good idea to pull the pump and clean the fuel filter and fuel mesh strainer too.
Good luck!
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
