Belt drive conversion. - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Main Category > Sport Touring / Trips
Sport Touring / Trips Well you asked for it. Post all of your sport touring and trips information, questions and stories in this area.
Reply
Thread Tools Display Modes
Old 11-17-2009, 08:42 AM   #1
rc4man
Junior Member
rc4man's Avatar
Bikes: Suzuki SV 1000S
Miles Kms: 24000
Hello All, just picked up an '03 SV1000S from my 71 yr. old neighbor (he's switched to a V-Strom). It's got Yosh slip-ons, PC III, K&N, GIVI flip up shield, GSXR Radial brake fork, Handlebar risers, reworked saddle (added padding).
My intention is to use it as a Sport Touring mount that is more comfortable to do miles on than my V-Rod.
I'm wondering if anyone has done a rear belt drive conversion on these. The V-Rod has spoiled me there, 31000 miles, it's clean, quiet and I have yet to have to adjust the tension.
The HP is fairly equal so I have no worries about strength or durability.
__________________
"V-ROD Forman", '04 Anodized "B", 50th B-day gift from Darling Wife. '03 SV1000S, gift to self. http://www.mem.com/Story.aspx?ID=2528706
rc4man is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-17-2009, 08:45 AM   #2
Zachmaster
Senior Member
Zachmaster's Avatar
Bikes: '08 Sv650SF, '08 Buell XB12R, '08 Husaberg Fe450, '92 GS500E
Miles Kms: I lost track....enough
Re: Belt drive conversion.
Gotta love the belt I am interested as well if anyone knows about it. The buell rode sweet
Zachmaster is offline   Reply With Quote
Old 11-17-2009, 08:46 AM   #3
dan46n2
BannedCampCounselor
dan46n2's Avatar
Bikes: 02 SV, 08 200 XCW
Miles Kms: not enough
if you search, there's a humongous thread discussing the topic.
dan46n2 is offline   Reply With Quote
Old 11-17-2009, 08:56 AM   #4
rc4man
Junior Member
rc4man's Avatar
Miles Kms: 24000
Quote:
Tried a search, you have a particular thread link?
__________________
Old 11-17-2009, 09:50 AM   #5
Coalfreak
Member
Coalfreak's Avatar
Bikes: Red '99 SV650
Miles Kms: Wish I had more....
Here's a link to it..this discussion started back in '05. Zak650's been working on this exact idea.
http://forum.svrider.com/showthread....ght=belt+drive
Coalfreak is offline   Reply With Quote
Old 11-17-2009, 10:01 AM   #6
bottlerocketdodger
Member
bottlerocketdodger's Avatar
Bikes: SV650 Naked 2005
Miles Kms: 9500
I'm starting to think a <$500 kit will never see the light of day. I are dissapoint.
__________________
You got it buddy the large print giveth and the small print taketh away. -Tom Waits
Basset Hound Owners Club Member #001
bottlerocketdodger is offline   Reply With Quote
Old 11-17-2009, 10:28 AM   #7
rc4man
Junior Member
rc4man's Avatar
Miles Kms: 24000
Quote:
Is that, $500, what it would take to make it practical/desirable?
I read some of Zak's postings and he expresses issues with strength and longevity.
I don't understand. The V-Rod guys, myself included, have been running them since introduction in '02 without major issue. The serious drag racers do switch to chains but there are the majority that do not. Additionally Gates has developed a narrow section Kevlar belt for HD thats even stronger than the stock offering.
There were some comments about torque vs. HP as a detrimental factor with disparaging remarks about the lower output ratings of Sportsters but the 1130 and 1250 Revo engines have no less than the typical SV1000 and still manage to get 50+k miles per belt. Additionally the typical V-Rod weighs 200 lbs. more than the SV which must increase loads due to acceleration.
As commented earlier, I've got over 31k miles on mine (V-Rod) without adjustment, and I'm now on my 6th rear tire. I marked the snail adjusters and swingarm the first time I removed one and have set it at that location with every change and the tension remains within spec.
Interesting.
I will have one by spring.
__________________
Old 11-17-2009, 10:57 AM   #8
Coalfreak
Member
Coalfreak's Avatar
I don't think the issue is the belt itself handling the torque of the motor, but rather the much tighter turn it has to take to get around the countershaft sprocket. The tighter the bend, the more wear the belt will experience, and it will have to make a much tighter turn on the SV, since it is smaller than a Harley, and has tighter clearances for the driveline. That, and the issue Zach had with the belt "climbing" the sprocket, and stripping the teeth off, which is also probably due to the tighter turn.
Old 11-17-2009, 12:57 PM   #9
rc4man
Junior Member
rc4man's Avatar
Miles Kms: 24000
I have yet to remove the engine sprocket cover. If there is room you can go larger on both front and rear to keep similar gear ratios. The swingarm section is large at the front (larger than the V-Rod) and there are chain guides to prvent damaging the aluminum swingarm as much as guiding the chain, which add additional bulk.
I don't currently know the stock rear drive ratio or sprocket sizes to calculate. Currently V-Rod riders have available anything between a 26-30 tooth front with 70-72 tooth rear. That provides a range from 2.33:1 to 2.77:1
Larger sprockets would enable the belt to clear the potential rub areas of the swingarm and promote longer belt life.
__________________
Old 11-17-2009, 01:04 PM   #10
jdewkilla
Senior Member
jdewkilla's Avatar
Bikes: '00 SV650 N
Miles Kms: 1st rebuild of the 2nd motor
The belts do use much bigger sprockets.. more surface area is how they keep the belts from jumping teeth under hard acceleration
__________________
Dancing is forbidden
jdewkilla is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
