Hard starting, spark plugs or valves? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 10-05-2009, 01:12 PM   #1
Vlasic
Member
Vlasic's Avatar
Bikes: 2007 SV1000s
Send a message via ICQ to Vlasic Send a message via AIM to Vlasic
My bike has trouble starting, especially in the mornings. By trouble I mean that I have to hold down the starter button for about 3-5 seconds. Sometimes it will just crank for a while and eventually catch and sometimes Ill crank it and it will catch but then struggle for a bit before idling correctly. Very often I will start up the bike and during start up it will choke and struggle a bit and once it gets to idle the red light will be blinking with FI on the screen. I have not pulled the code when that comes up but I am assuming that it is a misfire code from the bike misfireing during the hard start up.
The bike has just under 11k miles, I do regular maintenance on the chain and oil changes but I have not yet changed the spark plugs or adjusted the vales. How often are you suppose to adjust the vales and change the spark plugs? Could my hard starts be the result of old plugs or valves that need adjusting?
Vlasic is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-05-2009, 01:20 PM   #2
tovar
Senior Member
tovar's Avatar
Bikes: mali tovar
Re: Hard starting, spark plugs or valves?
Pull out code and see what it is. Maybe it is tps. You should change plugs every 10k but they will not give you light and code. Neither will valves out of adjustment.
tovar is offline   Reply With Quote
Old 10-05-2009, 03:57 PM   #3
Spierings
Senior Member
Spierings's Avatar
Bikes: k3 sv650n
Quote:
+1 Get the code first. There is no misfire code. If your FI light is burning you have other problems.
CODE MALFUNCTION PART REMARKS
COO None No defective part
C12 Crankshaft position sensor (CKPS) Pick-up coil signal, signal generator
C13 Intake air position sensor (ZAPS)
C14 Throttle position sensor (TPS)
C15 Engine coolant temperature sensor (ECTS)
C21 Intake air temperature sensor (IATS)
C23 Tip over sensor (TOS)
C24 Ignition signal #1 (IG coil #1) For #1 cylinder
C25 Ignition signal #2 (IG coil #2) For #2 cylinder
C28 Secondary throttle valve actuator (STVA)
C29 Secondary throttle position sensor (STPS)
C31 Gear position signal (GP switch)
C32 Fuel injector signal #1 For #1 cylinder
C33 Fuel injector signal #2 For #2 cylinder
C41 Fuel pump control system (FP control system) Fuel pump relay
C42 Ignition switch signal (IG switch signal) Anti-theft
C49 PAIR control solenoid valve
__________________
My build thread:
http://forum.svrider.com/showthread.php?t=117161
Spierings is offline   Reply With Quote
Old 10-05-2009, 04:10 PM   #4
Vlasic
Member
Vlasic's Avatar
Bikes: 2007 SV1000s
I looked up how to get the bike in dealer mode and pull the code but Im not sure how Im suppose to do it. I understand that I have to put a wire or paper clip in the dealer mode connector but, I insert the wire while the bike is off and then turn the bike back on correct? The FI light doesnt come on every time I start the bike, only sometimes. Most of the time when I turn the bike off and then back on the code is gone. I tried to pull the code right now and got -c00.
Old 10-05-2009, 04:17 PM   #5
Spierings
Senior Member
Spierings's Avatar
Bikes: k3 sv650n
Quote:
When you turn the bike off you will reset the system. Put it in dealermode when the light is burning without turning the ignition off or leave it in while starting.. The c00 code = no malfunction
__________________
My build thread:
Old 10-05-2009, 04:39 PM   #6
Vlasic
Member
Vlasic's Avatar
Bikes: 2007 SV1000s
Got it, the light doesnt come on every start so Ill have to play with it for a while. Hopefully I can get it to come on today.
Old 10-05-2009, 04:44 PM   #7
andyauger
Supporting Member
Bikes: 2001 SV 650
You haven't changed the plugs in 11K miles? Do that now. You're late. See if that helps.
Valves aren't the first place I'd look for hard starting issues. In your case I'd suspect spark as the #1 problem.
You might try running some Sea Foam in the next tank of gas, especially if the bike is stored outside.
You should also look to see how dirty the plug caps are. I've seen caps that arced due to an accumulation of road grime.
Air filter?
Start with the obvious, basic maintenance.
andyauger is offline   Reply With Quote
Old 10-05-2009, 04:58 PM   #8
RandyO
Site Supporter
RandyO's Avatar
Bikes: nekid red 99-135k 07VeeStrom1k- 70k
The bike has just under 11k miles, I do regular maintenance on the chain and oil changes but I have not yet changed the spark plugs or adjusted the vales.?
you have ignored recommended tuneup maintenance
imho thats's all you will; need to do
plugs
air filter
tps adjustment
throttle body syncronization
your starter will thank you for keeping up with ALL recommended maintenance
don't worry avout valves until 15k
__________________
RandyO
IBA#9560
A man with a gun is a citizen A man without a gun is a subject
RandyO is offline   Reply With Quote
Old 10-05-2009, 06:19 PM   #9
Vlasic
Member
Vlasic's Avatar
Bikes: 2007 SV1000s
Thanks guys, didnt know the plugs in bikes had to be changed so often.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
