Wheel Bearing Removal - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 07-27-2009, 10:44 AM   #1
NINJAdoc
Member
NINJAdoc's Avatar
Bikes: 07 SV1K, 07 SV650, 990SMR, DRZ
Any ideas for pulling front or rear wheel bearings without the Suzuki tool? I'm replacing the rear bearings on an SV1K. Thought I could gently tap out from the opposite side by using the middle spacer, but can't get enough of a lip showing for my punch or drift pin. What's everybody else do?
NINJAdoc is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-27-2009, 11:21 AM   #2
Cider
Senior Member
Cider's Avatar
Bikes: '02 naked
Miles Kms: 8000
Re: Wheel Bearing Removal
I bought a bearing puller from Harbor Freight and used a heat gun to loosen things up a bit. They come out pretty easy that way, but every time you pull them, you risk damaging them.
Cider is offline   Reply With Quote
Old 07-27-2009, 11:39 AM   #3
wacky_woodchuck
Supporting Member
wacky_woodchuck's Avatar
Bikes: Hawkman Rocket Cycle
Send a message via ICQ to wacky_woodchuck Send a message via Yahoo to wacky_woodchuck
Harbor Freight bearing removal kit is very nice. It's $40 regular price, sometimes they let is go down to $30. Works great for the one or two times you are going to use it.
__________________
Quote:
This isn't happening, Dale. We're not here. It's just a bad dream.
wacky_woodchuck is offline   Reply With Quote
Old 07-27-2009, 01:07 PM   #4
NINJAdoc
Member
NINJAdoc's Avatar
this one?
View more Pittsburgh items
Blind Hole Bearing Puller
Designed especially for pilot bearings and other jobs that require an internal puller.
3 lb. slide hammer with T-handle for secure grip
Chrome-plated shaft for smooth operation
Four collets: 3/8" to 1/2", 9/16" to 11/16", 5/8" to 1", 1" to 1-1/4"
Blow mold case
Weight: 7.6 lbs.
ITEM 95987-2VGA
$39.99 Email link to a friend
Old 07-27-2009, 01:17 PM   #5
RichDesmond
RichDesmond's Avatar
Bikes: Ducati 848, GS1000S, SV650, 650 V-Strom, DR-Z400S, RZ350
Quote:
Never had a problem using a punch and hammer. Don't hit the spacer, run the punch down through the spacer and hit the inner race on the bearing directly. Replace with new bearings.
__________________
Rich Desmond http://www.sonicsprings.com
RichDesmond is offline   Reply With Quote
Old 07-27-2009, 01:24 PM   #6
NINJAdoc
Member
NINJAdoc's Avatar
yeah - I was thinking after looking at a couple other forums that I might be able to actually hit the backside of the bearing, rather than the spacer. I didn't think about moving the spacer out of the way so I can get my drift pin onto the backside of the bearing I'm trying to tap out. I'll give it a shot 2nite.
Thanks!
Nd
Old 07-27-2009, 06:17 PM   #7
wacky_woodchuck
Supporting Member
You posted the right bearing puller. Works much better than a drift and hammer. Though even using the bearing puller, you will still need to replace the bearings.
I did my rear wheel bearings both ways. The drift and punch took quite some time (maybe 25 minutes to get out). The bearing puller took maybe 3 minutes, with no heat.
The tool was worth the $30 (I got it on sale). Also, in the latest Cycle World, Harbor Freight has a 20% off one item coupon.
__________________
Old 07-27-2009, 06:46 PM   #8
imdying
Senior Member
imdying's Avatar
Bikes: SV1000R
Give it the learn with a punch and hammer. Take you about 15 minutes on your first wheel, and about 2 minutes for every other. Give the spacer a nudge, then bash bash bash The opposite side, well, you won't need any instructions on that one!
Never reuse the bearings... a quality double sealed bearing is about NZD$6, so I'm guessing that you're looking at about USD$2 each in The States
__________________
Quote:
I want a hobby, not just a bike
imdying is offline   Reply With Quote
Old 07-27-2009, 09:11 PM   #9
NINJAdoc
Member
NINJAdoc's Avatar
Easy as pie - tapped 'em out with the hammer and drift (no heat needed), last nite I was trying to knock 'em out by hitting the opposite end of the spacer and kept loosing the edge. If I can find that HF coupon I may go ahead and pick up a bearing puller, "just in case." Got the bearings for $9 each, may have to go to Suzuki for the seal though.
Appreciate everyones' suggestions and advice!
Nd
Old 07-27-2009, 09:33 PM   #10
inuyasha
Senior Member
inuyasha's Avatar
I was thinking of doing this...where can I pick up the correct bearings for my 1st gen?
__________________
02 SV650 Naked Mellow Yellow
inuyasha is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
