starter motor not working - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 07-14-2009, 10:40 PM   #1
UpperSouth
Junior Member
UpperSouth's Avatar
Bikes: 2001 Suzuki sv650s
Miles Kms: 16,000
Question starter motor not working
after having to bypass the clutch relay (because i broke it on a triler delivering my bike), the starter motor doesnt run for some reason. i switch on the engine engage switch and hear nothing. lights and signals work fine. i think something might have broken somewhere on the left handgrip, signals work but no horn (wierd)
what might be the problem?
UpperSouth is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-15-2009, 10:55 AM   #2
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Re: starter motor not working
When you say "i switch on the engine engage switch" do you mean, turn on the ignition key switch, or push the starter button, or flip the kill switch.
Had the bike been sitting for a while?
__________________
The truth will set you free... but first it will pis you off! -anon
TeeRiver is offline   Reply With Quote
Old 07-15-2009, 10:30 PM   #3
LobsterMagnet
Junior Member
Bikes: 2001 sv650
Miles Kms: ~10k
Send a message via AIM to LobsterMagnet
Check the related switches.
Clutch kill switch: I'm assuming that by "bypassing" it you essentially have it constantly engaged. IF NOT, take your shift lever off, look inside the recess and look at the little white switch. Pull it out towards you and try to turn the engine over.
Make sure that it is connected, play with the plug below the horn button.
Kickstand kill switch: Flip the kick stand down, look behind it above the connected spring, and you'll see a sort of upside down mushroom. That's the kill switch. Play with it.
If you messed with the clutch kill switch then that is most likely the culprit.
LobsterMagnet is offline   Reply With Quote
Old 07-16-2009, 07:08 PM   #4
UpperSouth
Junior Member
UpperSouth's Avatar
Miles Kms: 16,000
flipped the kill switch
Old 07-16-2009, 10:12 PM   #5
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
OK good, what happens when you hit the starter button?
__________________
Old 07-21-2009, 09:24 AM   #6
superdonka
Junior Member
superdonka's Avatar
Bikes: SV 650s
Miles Kms: 6600
If the bike has been sitting for a while what could it be?
superdonka is offline   Reply With Quote
Old 07-21-2009, 01:25 PM   #7
TeeRiver
Moderator
TeeRiver's Avatar
Bikes: '03N, '07N
Miles Kms: ~44/gal
Sitting for too long will kill the battery and can permanently damage it if it stay completely discharged for too long.
Since the bike had been trailered I was suspecting the bike might have sat for a while. Even though the OPs lights work, the battery might not have enough juice to turn his starter.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2009 SVRIDER.com.
