Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > SV Modifications and General Maintenance
Register Forums FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read
SV Modifications and General Maintenance General information about modding and servicing your SV.
Reply
Thread Tools Display Modes
Old 01-22-2008, 11:31 AM   #1
wacky_woodchuck
Supporting Member
wacky_woodchuck's Avatar
Bikes: 1986 Freightliner, The one with the sleeper cab, big enough for two
Send a message via ICQ to wacky_woodchuck Send a message via Yahoo to wacky_woodchuck
Re: Factory Pro Shift Kit install- LONG read w/ lotsa pics
Quote:
Originally Posted by orangegilly View Post
Apparently, the mods found a way to resurrect this thread, but the links needed fixed to work with the new board. Updated the links, and it's all back to normal.
Thought I'd bump it up if anyone needs to do this this winter (*cough* wacky *cough*).
What? I need to do this? Well...maybe. except I'll but the 05 stuff and save a little bit of money... But then again.. if I do it, it's only because I'll have my clutch off to inspect the 8 years of clutch plate use...and to install some Barnett springs.
__________________
Quote:
This is Jack Burton in the Pork Chop Express, and I'm talkin' to whoever's listenin' out there.
wacky_woodchuck is offline   Reply With Quote
Old 01-22-2008, 01:15 PM   #2
orangegilly
Site Supporter
orangegilly's Avatar
Bikes: 2000 SV650
Miles Kms: 25k+
Quote:
No kidding.....Hmmmm.
orangegilly is offline   Reply With Quote
Old 01-23-2008, 03:10 PM   #3
etham
Senior Member
etham's Avatar
Bikes: Silver '02 SV650s
This is a good candidate for a wiki post! If you don't do it, Orangegilly, I will do it for you. See my sig.
Also, are there other mods that could / should be done at the same time?
__________________
~ Matthew
etham is offline   Reply With Quote
Old 01-24-2010, 05:37 PM   #4
jglSV
Site Supporter
jglSV's Avatar
Bikes: '01 SV650, '98 900SS FE, '05 Multistrada
Miles Kms: 13,000
Need some help with my shift kit install. I got the new detent arm and spring in place without too much drama. (I too dropped the washer behind the arm in the oil pan, but fished it right out with the wonderful magnet tool.)
I was very careful to keep everything in the right position and reinstall just the way it was. But, somewhere along the way I failed. When I put the clutch basket back on and tested the shifter, it wouldn't go smoothly into all the gears, I could get them all in by moving the rear wheel slightly, couldn't smoothly snick thru all the gears without moving the wheel. Wasn't even always the same gear that was a problem.
Apparently, I got the gear dogs out of position at some point. Any suggestions? Plan to call Factory Pro hotline tomorrow, but thought I'd toss it up here first.
__________________
sonic springs|racetech emulators|penske double|shift kit|vortex clipons|veypor gauge|woodcraft rearsets|micron full sys|r6 throttle tube|gsxr calipers|galfer lines
jglSV is offline   Reply With Quote
Old 01-25-2010, 08:59 PM   #5
ineedanap
Member
ineedanap's Avatar
Bikes: 03 sv650s, 08 hayabusa, 09 buddy scooter
Miles Kms: 8,000
Sounds normal.
On lots of bikes you can't just click the shifter through all the gears without turning the rear wheel slightly or having the engine running. Maybe 2 or 3 before it won't shift further, but not 6.
My nearly new busa, my not so new SV and my ghetto old GS have always done this.
ineedanap is online now   Reply With Quote
Old 02-06-2010, 06:50 AM   #6
jglSV
Site Supporter
jglSV's Avatar
Miles Kms: 13,000
Quote:
Originally Posted by ineedanap View Post
Sounds normal.
Apparently, it is normal. I called Factory Pro and they said you have to move the wheel to get it into all the gears. So, I'm ready to go for a test ride! if only for the fact that is 23 degrees and windy out...
__________________
Old 04-22-2010, 06:06 AM   #7
jglSV
Site Supporter
jglSV's Avatar
Miles Kms: 13,000
Quote:
Took the beast out for a spin last weekend and the transmission shifts like butta. This is going to make shifting at M-O this weekend a joy.
__________________
Old 02-06-2010, 10:09 AM   #8
orangegilly
Site Supporter
Bikes: 2000 SV650
Miles Kms: 25k+
Hey old thread! Glad it's still around helping people out.
Old 02-07-2010, 06:25 PM   #9
canyonchaser
Supporting Member
canyonchaser's Avatar
Bikes: Willy's SV650. 1, EACH
Miles Kms: 150k grand total
Since this thread zombied, I'd like to share some words of wisdom to help others make sure they do this correctly.
Firstly, it is critical, and very, very easy to get this wrong; but it's critical to ensure the clutch basket aligns with the oil pump gear when you put things back together. Like i said this is really easy to get wrong. If the teeth don't line up perfectly you'll either fail to spin the oil pump and bad things will happen or you'll break the oil pump gear in half and bad things will happen. Even if you are a bit ham-fisted you can crack the oil pump gear and eventually have bad things happen.
Second. Make sure you get final bolt holy-hell tight. If this is even a little bit not tight enough it will eventually loosen up (despite the lock washer that you bend over the nut) and bad things can happen.
Two of these that I've done; one had a oil pump gear break, the other, the Army SV, the final nut worked its way loose, but I was lucky to have found the problem before it caused any trouble.
dp
canyonchaser is offline   Reply With Quote
Old 07-05-2010, 05:39 AM   #10
Apollo1777
Titanium Member
Apollo1777's Avatar
Bikes: 02 SVS Candy Blue
Miles Kms: day-dreaming about living someplace WARM, motorcycling, work, nursing...
Send a message via AIM to Apollo1777
For those unfamiliar, the clutch likes to spin, and it's hard to loosen or torque the main clutch bolt without a holding tool.* Here is my tool in use.* The shoulder bolt fits in the swingarm pivot, and the two 6mm bolts screw into the clutch basket where the clutch springs go while still leaving access to the nut:
what is the size of that nut!? I bought a 26mm socket but it doesn't fit! (I would HATE to make a trip to SEARS for a 27mm socket only to find out I need a 28mm one.. haha)
__________________
Modifying My 02 SV650s . . .
Quote:
Originally Posted by ShaggyZ View Post
Zoran's truths are timeless and without bound. He's the type of guy that can literally slap you through the phone or send a fart through email.
Apollo1777 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
©1999-2009 SVRIDER.com.
