| Register | Forums | FAQ | Gallery | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| SV Modifications and General Maintenance General information about modding and servicing your SV. |
Thread Tools | Display Modes |
#1 |
Site Supporter
Bikes: 2000 SV650
Miles Kms: 25k+
Factory Pro Shift Kit install- LONG read w/ lotsa pics
So a few years ago (2004, I think), I bought the Factory Pro shift kit with detent star.* Yeah....the expensive one.* It was $200, I think.* I always thought it was pretty steep, but I had heard that it really made a difference in getting positive shifts.* I was also getting quite a few false neutrals and my bike had been popping out of second gear on hard acceleration.
So ponied up for the kit, and then made a focused effort to improve my shifting technique.* Most of my issues were due to having a lazy foot, and were improved by improved technique while shifting.* However, I still had this kit.* Thought about selling it on ebay, but never got around to it. Then, sometime last year, I learned that the stock '05+ SV parts were nearly identical to the Factory Pro kit (see HERE), thereby rendering my kit's value to about $40.* No point selling it at a loss, so I decided to put it in.* I read up on the install directions, and decided at the time that it was beyond my comfort level, so it sat for another year. Fast forward to this past weekend.* After reading through the thread by mackeystingray over on BARF, I felt reasonably comfortable that I could pull it off....so I gathered almost all the tools necessary (snap ring pliers are VERY helpful, btw) and started turning wrenches.* Here's before I got started (and what I hoped I could get back to when all was said and done): ![]() I was very careful to keep track of where all the bolts went, as there's a few different sizes used to hold the clutch and side cover on: ![]() Based on mackey's thread, I learned that I needed a 'clutch holding tool.'* Having never removed a clutch (or even the clutch cover, for that matter), I had to do a little research on what this tool was and did.* There were some nice tools I found on ebay and Motion Pro....but I wasn't looking to spend much money on one, so I decided to make my own out of a shoulder bolt, a couple nuts, and a piece of 1/8" x 1" bar stock from home depot (total cost ~$6).* The black tape was to keep from scratching the basket or my frame: ![]() For those unfamiliar, the clutch likes to spin, and it's hard to loosen or torque the main clutch bolt without a holding tool.* Here is my tool in use.* The shoulder bolt fits in the swingarm pivot, and the two 6mm bolts screw into the clutch basket where the clutch springs go while still leaving access to the nut: ![]() With the side cover off, and the clutch out, this is what you see: ![]() Here's what it looks like with the detent star and stopper arm removed: ![]() New parts installed (oooh, shiny!): ![]() I did have a few issues, however, that took my install time from what should have been about 3 hours or so....to about 12 hours.* I did have the clutch springs and basket apart 3 different times, I think.* When I initially removed the stopper arm, the arm, the bolt, the spring, and the little washer that goes behind the arm fell down into the 'pan' cavity of the engine.* I fished out the arm, spring, and bolt with a magnet, but the washer wasn't there....and it was late Saturday night and I didn't read the instructions all that closely (I was too tired, apparently).* So the first time I put it back together, it was wrong as I didn't use the washer. I didn't realize there was a washer behind the spring, as I didn't see it when I pulled the stopper arm out.* I found the 'updated' thread by mackey over on BARF (I had been using the older thread as a guide).* It would shift, but wasn't what it should have been.* So I ripped it all apart again, this time only removing the clutch cover.* I looked all over for the washer, and tried the magnet thing again, but to no avail.* I also inspected the stopper arm, and it appeared to be lined up correctly with the detent star, so I put it all back together (it's now about 3am Saturday night). Sunday morning, I had a ride planned....and thinking I was done, went out and attempted to leave.* BIG PROBLEM....there was so much clutch drag that I couldn't go anywhere.* I would shift into 1st from neutral, and it was pulling so hard that it would stall the bike.* I adjusted the clutch under the cover, but to no avail.* It was still pulling HARD.* Soooo, back in the garage.* I rip it apart again....the joys of learning.... ![]() I pull the clutch, and in the meantime, send an email to Zoran asking him about the washer I think I lost.* I pull the detent star and the stopper arm back out, and sure enough....no washer.* It's so much easier now that I have snap ring pliers (thank you Harbor Freight).* Since I can't find the washer, I grab a standard 6mm washer from my kit of nuts and bolts.* I also had to open up the hole a little bit on the stopper arm, as the shoulder on the stock bolt would not seat properly into the hole in the arm (dremel).* I also measure the springs and clutch plates to determine if they're still in spec to the manual.* The springs are close to being out of spec, but still right at the low end of the tolerance.* The clutch plates are fine.* I don't see anything that looks like it would cause the amount of drag I was getting, so I think the springs are at fault. I continue inspecting the parts, and finally realize that I had the clutch pack assembled wrong.** * In my haste at 3am, I had accidentally put 2 metal plates together and also had 2 friction plates together.* I think when I pulled the stack, that I had left one friction plate in the basket, then started from the wrong side of the stack when I reassembled it.* Lesson learned....if you're tired...don't rush things.* Well, that and don't work on the bike at 3am in the morning.** ![]() So I get it back together, take it for a short ride, go home, and then get an email back from Zoran.* He suggested pulling the hex-head drain plug, as the oil flows right past it, and that's where most particles collect in the SV motor.* Sure enough, I pop out the plug, shove my magnet up there after the oil drains out, and I pull out the washer I lost the night before!* It must have rolled pretty far down the oil passage, as I never saw it.* Zoran is the man, once again!! So, after about 12 hrs in the garage for a <3 hr job, it's done and the bike shifts AWESOME!!* I don't have to think about shifting anymore.* It snicks right into gear, feels very positive, and is definitely quicker than before.* I love it.* If anyone has a pre-2005 SV, this mod is highly recommended.* If your SV is somewhat hard to shift, you NEED to do this (well, not like I did it, but still).* Is it worth $200? No. Is it worth $40? Without a doubt. The '05 p/n's are listed over in the thread on BARF, and at ronayers, total up to less than $40.* I could probably do this now in about 2 hrs on a 1st gen, and about 3 on a 2nd gen, as the 2nd gens have a one-piece side cover.* It's really not that hard, especially with all the right tools.* Hopefully, my errors will help prevent someone else in the future. Thanks to mackey for a great write-up, thanks to wacky for listening and helping me trouble-shoot, and thanks to Zoran for being the be-all, end-all knowledge source for all things SV.* |
#2 |
Re: Factory Pro Shift Kit install- LONG read w/ lotsa pics
I really like it myself... Not the best mod ever but it feels great, and gives a nice quality feel to shifts. Hardest part for me was getting the circlip off the selector shaft wotsit without a pair of circlip pliars
That, and cleaning scraps of gasket off the case. I like your clutch tool using the swingarm pivot, that's now in my list of ideas to steal.
Twin Works Factory: www.twfracing.com/ Or can be found on many other excellent messageboards. |
#3 |
Does the shift kit make it feal stiff to shift my 04 seems real stiff compaired
to my stock gsxr 1000 im not sure if it has a shift kit or not as im the third owner John |
#4 | ||
Site Supporter
Bikes: 2000 SV650
Miles Kms: 25k+
  The 6mm bolts are either 25 or 30mm length, and the big bolt is a M8 shoulder bolt that's either 35 or 40mm long.  Used one regular nut to run up on the shoulder, and a nylock nut to hold the two arms together.  ![]() Quote:
#5 | |
Titanium Member
OG, it looks like the radiator is hooked up to the same area... So, will I have to drain the radiator as well as the oil before taking that clutch cover off??
#6 | |
Supporting Member
You are forcing me to spend the $40 now aren't you
![]() Well, it'll have to wait as I tried to fire up the SV for the first time sice fall. The battery is kaput... even with it being on a trickle charger all winter.... it doesn't even have enough juice to allow the guages to turn on. Nice write up...
#7 | |
Site Supporter
Bikes: 2000 SV650
Miles Kms: 25k+
![]() Good thing you have one of those unreliable Buells as a back-up.
#8 |
Supporting Member
Bikes: 03 SV1Ks, 00 DRZ 400k
Nice write up Keith.
#9 |
Supporting Member
Bikes: RS125R
add another thing to do when i get a garage.
sometimes living in brooklyn really sux.
#10 | |
But false neutrals are greatly reduced by the kit. Positively encourages Lazy Foot, in fact, riding a standard bike needs some adjustment I found. One thing is, it's incredibly intolerant of bad clutch adjustment and shifting into neutral, not really a drawback since it only occurs if you have bad clutch adgustment, but it's something to watch for. I agree that rearsets give better shifting than stock controls, at least, mine give better shifting than my rather worn out stockers. Less play in everything.
| Thread Tools | |
| Display Modes | |
