New User? Register - Forgot Password | ||||||
| Register | Forums | Garage | FAQ | Gallery | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Motorcycle Escrow | Insurance |
| 03 + SV650 Tech Info, advice or questions specific to the 2003-up model SV650. |
Thread Tools | Display Modes |
#1 |
Supporting Member
![]() Join Date: Jul 2008
Bikes: 02 SV650, 04 SV650S, 03 ZX636, 06 WR450F
Miles Kms: 8000 miles, 11,000 Miles, 10000 miles
04 Cam Chain Tensioner upgrade to 05+
My 04 front cam chain is noisy so I've been investigating using automatic cam chain tensioners from an 05+ SV650 that have the updated ratcheting mechanism.
I've checked the parts fiches and found that the cylinders and cam chain guides have the same part numbers so the later tensioner should fit. Has anyone fitted or investigated installing the later tensioner, if yes, what did you discover ?
Custom Upper Triple Clamps: http://sites.google.com/site/s1sv650...xr-conversions Facebook: http://www.facebook.com/pages/Sv650-...58635964187662 |
| Sponsored Links | |||
Advertisement | |||
#2 |
Supporting Member
Re: 04 Cam Chain Tensioner upgrade to 05+
Anyone
#3 |
Bikes: 03 650, almost supersport but almost a superbike
Miles Kms: 3500 miles in the previous life
It's a motorcycle with a cam chain. The engine is not surrounded by fairings. Even with fairings, they are still a little rattley. It's always going to be noisy. New tensioners won't change it.
Plan for my K3. Lighten, lighten some more, then add power. Reliability is having a spare motor. Need to work on reliability. |
#4 | |
Supporting Member
Do you know if they're interchangeable ?
#5 |
The mechanical ones are interchangeable. I don't recall when they went to hydraulic. That won't work.
What issue is there? Did you install it with the ratchet facing up?
#6 | |
Bikes: SV677 Superbike
WERA #117 |
#7 | |
Supporting Member
. It's been a year since I built it and I just can't remember the CCT installation. Thanks a lot for the info. So I have the latest CCT's available for my 04 already ?
#8 | |
Supporting Member
It didn't rattle before the rebuild so I guess I'll check the installation and reset the CCT and then see what it's like. I was mostly curious if there was an easy upgrade from a later year available.
#9 |
Bikes: 01 suzuki sv650 special
Miles Kms: MANY SOON !
Hi,
Sv650.org has a tensioner adjustment page seems might help here. I will send a pm about triple question I have. Regards,Ed |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
