Charging Issues - Page 2 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > 99-02 SV650 tech
Register Forums Garage FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read Motorcycle EscrowInsurance
99-02 SV650 tech Info, advice or questions specific to the 99-02 model SV650.
Old 05-18-2012, 11:37 PM   #11
inuyasha
inuyasha's Avatar
Re: Charging Issues
Originally Posted by champer View Post
Make sure to check your stator also. Test the 3 yellow wires to ground, none should be "short" - all should have full resistance (no path to ground). Test the 3 wires to each other, there should be very little resistance.
Which yellow wires are these? Is it the yellow wires on the other end of the connector to the RR?
I think my RR is suspect as well cause my battery isn't charging at 5k RPM, but I want to rule out the stator obviously.
I also want to add while doing the cam swap, to access the rear CCT, I unscrewed a thick negative wire thats beneath a green cover case with fuses (starter power?). While reconnecting, I accidently touched the black wire with the RED wire causing sparks and it also tried to turn over the engine. I'm thinking this may have shorted the RR, battery, or something else... Any correlation?
Something is draining my battery.
02 SV650 Naked Mellow Yellow
inuyasha is offline   Reply With Quote
Old 05-19-2012, 04:31 PM   #12
RMAN
Supporting Member
Bikes: Triumph T595 Daytona, '01 SVS SOLD
Miles Kms: 7,660 & 22,000
Re: Charging Issues
You shorted the starter relay which tried to start the motor. A problem if the bike is in gear. Probably did not harm any electrical components. The main 30A fuse would protect those as well as other fuses. The stator wires are the three yellow wires. You would test for voltage output and ground using the three wires in the connector on the harness side as you stated, not obviously on the R/R side. I'll post the service manual page on stator testing for you.
RMAN is offline   Reply With Quote
Old 05-19-2012, 04:32 PM   #13
RMAN
Supporting Member
Re: Charging Issues
Old 05-21-2012, 08:54 AM   #14
champer
Bikes: 2000 SV650s
Re: Charging Issues
Yes.
Buncha SV's...
champer is offline   Reply With Quote
©1999-2009 SVRIDER.com.
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
